Originally Posted by G|F.E.A.D|Killa
Alright so i have been trying to build a 4AFTE on paper for some time now and have come up with a cheaper option to standalone systems. what im looking at is as followed:
a 10:1 FMU
bigger injectors (looking at the best option right now) maybe 270ish CC
T3 turbo
A FPR that can handle the extra fuel
255lph pump
a way to keep the map sensor at - pressure maybe some check valves.
im gonna start at 4 or 5 PSI and move up from there and see what i can do, also as im building a built high comp 7age for it later on so im not looking to spend alot of money. now i know that style of FMU is old and out dated but i dont care. i just want something that works. what do you all think, can anyone think of anything im missing.
Dont mean to sound like a broken record but engine management is one of the places you dont wanna cheap out on. That being said, an fmu can work for a low boost application . Jmaz has been using one on his 4afte for years. We used one on a 4afze we built sometime ago. You dont need bigger injectors , stock ones will do for a fmu.
Another cheap option is to get a 2 bar map sensor (3sgte,4agze) and get injectors approx 2x the size of your stock ones (370cc approx)and that will handle low boost just fine.
