89 Corolla driver headlight dim, shuts off on hi-beam - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2011, 01:03 PM   #1 (permalink)
View mikeDOTexe's Photo Gallery
My driver headlight seems very dim and may not pass inspection. When on hi-beams, it shuts off, so only the passenger-side is lit.
I've read an unclear forum post about a mechanic grounding the headlamp wire to the radiator to fix this problem. Would this be the top wire on the three-plug setup?
This is an 89 coupe
mikeDOTexe is offline   Reply With Quote
Old 07-28-2011, 02:12 PM   #2 (permalink)
View MauiAL's Photo Gallery
Gen6
Since it is off completely when you turn on your hi-beams, I'm guessing you need to replace the bulb/sealed beam unit.
MauiAL is offline   Reply With Quote
Old 08-04-2011, 04:22 PM   #3 (permalink)
View mrherm1956's Photo Gallery
Replace the bulbs for each side and that otta work...
mrherm1956 is offline   Reply With Quote
