Engine overall/performance? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2011, 03:11 AM   #1 (permalink)
View djfoxx's Photo Gallery
AE92 Engine overall/performance?
Hi guys
I'm soon going to redo my whole engine including a branch and side drafts and just wanted to know from you guys how will it affect the performance and would you advise it? its a 1600 16valve 4a-f engine
djfoxx is offline   Reply With Quote
Old 07-31-2011, 01:15 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Side drafts work great on a 4A-F, particularly webers. Bike carbs are iffy. Find a way to connect the distributor to the carbs. Also while you're at it, get some camshafts for it. You'll be amazed.
Old 07-31-2011, 03:08 PM   #3 (permalink)
AE92
how do you do the distributer thing?
Old 08-01-2011, 11:47 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
well you have to get the vacuum lines connected. One goes to the intake manifold and the other goes to the carb plate.
Old 08-01-2011, 04:48 PM   #5 (permalink)
RogueMoog's Avatar
Gameroom cash: $313930
View RogueMoog's Photo Gallery
Someone makes "performance" camshafts for the 4AF (and 4AFE?) engine?
RogueMoog is offline   Reply With Quote
Old 08-01-2011, 07:43 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Yup and I can get custom made ones here too.
Old 08-02-2011, 04:30 PM   #7 (permalink)
RogueMoog's Avatar
Hmm. Can they run with a stock ECU setup? Or does the ECU freak out with what I assume are longer durations (and a little more power)? I mentioned in another topic that my friend and I are considering doing an NA "build" of my 4AFE, mostly to the head (switch to 1992 IM, open up intake & exhaust, port & polish head, custom exhaust manifold & exhaust).
Old 08-02-2011, 07:37 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
The ECU wouldnt know what the camshafts are, unless you go with really crazy ones, it should work.
92 IM wont fit a <92 head, bolt pattern, flange shape, inlet orientation is all wrong. You can get significant gains on a 4A-F with side drafts and cams... not so sure about the 4A-FE..
Old 08-02-2011, 09:51 PM   #9 (permalink)
RogueMoog's Avatar
Ah OK, thanks. Guess I'll have to pull an entire 1992 head with the IM etc to use in my 1988?
Old 08-03-2011, 02:31 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Then you need the lower belt pulley atleast as the belt has different toothing and length and size as the pre -92 engine..Plus other things...fuel injectors, fuel rail, etc..
