I was thanking 90 GP for explaining how to get the fusible links out.
For the record: The problem of the charging system was fixed by repairing a broken wire. It was broken off too close to the old connector to use a splice. I used the alternator connector off of an old engine and put it on the harness with crimp-on wire splices. The alternator connector has a thick white wire with green stripe (10 gauge), a black wire and a brown-and-black wire. The black wire was broken. The symptom this caused was that the voltage across the battery terminal with the engine idling read only about 12.3 volts, which was just the battery voltage. After the repair, it reads about 14 volts.
I find it hard to get crimp-on splices to hold. I used "bullet splices" on the thin wires. The male ends go on with no problem. It's hard for me to tell when I've gotten the female ends properly crimped, but I'm not using a special tool, if there is one. For the 10 gauge wire, I only found the single piece type of connector for sale.
