distributor ignition timing advance?.. side effect? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2011, 09:28 PM   #1 (permalink)
View lgene10's Photo Gallery
Question distributor ignition timing advance?.. side effect?
hi guys. i want to ask the ignition timing.. so i advance the ignition timing because i got more power in advance hmm.. not too advance.. about 80%.. guys do you think its ok to advance it?.. any bad side effect to the engine?.. or not?.. gas millage?..
lgene10 is offline   Reply With Quote
Old 08-06-2011, 10:16 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
80%! No way.
Try 2 -4 degrees., that'll be OK.
The Jedi Speeder at CarDomain
Old 08-07-2011, 04:41 AM   #3 (permalink)
hehe sorry i cant explain it right.. so im looking at the bolt.. for example 50 is the center. so i raise it at 75 something like that.. so when im driving and press the accelerator gently it got power. the rpm raise quick.. but when i put it on 50 or 40 for example i feel its underpowered and the engine too slow to response and i have to press the accelerator deeply to raise the rpm.. im happy at the engine performance right now.. so what do you think guys? if its ok to the engine?.. should i lower it a little? gas millage?..
Old 08-07-2011, 06:14 AM   #4 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
To set it properly you need timing light and plug vac lines at vac advance and any other requirements prior to adjusting it (see spec label on underside of hood). Using timing light you can adjust it within that 2-4 degree range of the factory spec stated on the label. If you alter it too much you risk engine pinging. If it is set to factory spec and everything else is set to spec on engine it should perform well without needing further adjustment.
90 GP is offline   Reply With Quote
