Intermittent inability to shift from 1st to 2nd gear at low speeds (manual tranny)
I've noticed increasing difficulty of shifting from first to second gear with my manual transmission.
This is not a constant problem, but happens intermittently, although with increasing frequency starting this morning. When this does happen, I can shift from 1st to neutral, but then it feels like I am hitting a blockage when shifting from neutral into 2nd gear. If I drive it a bit, then I can shift from 1st to 2nd fine; but later, the problem occurs again.
Occasionally I've had problems shifting from 2nd into 3rd, but I can easily shift from 2nd to 4th. But this has been a rare occurrence.
Shifting to the other gears are fine.
Shifting between the gears while the engine is off and the clutch is in seems fine.
There is no grinding or trashing of gears as far as I can hear. Rather, when the car is moving (and only when the car is moving), I press the clutch down, move the shifter from 1st to 2nd, but it stops in neutral and won't go into 2nd gear. If I coast a bit, or wait a bit, it will then go into 2nd, but since waiting can be dangerous if you are trying to merge into traffic, I will rev the engine to enter 3rd or 4th. For some reason, I can enter 4th gear at a lower speed than I can enter 3rd gear. If I try to enter 3rd gear at too low of a speed, I hear a grinding or thrashing of gears colliding.
But I do feel a "pop" and sometimes hear a hear a pop noise once I go into 2nd on some occasions. I had heard and felt similar sounds in the past, but it was very rare, perhaps once every few months. Now, I can feel it and hear it every time.
The clutch pedal travel distance does appear to be not as "tight" as it used to be. I am looking to adjusting this.
There appears to be sufficient clutch fluid in the reservoir and there are no leaks.
The clutch pressure plate and related parts are relatively new, about 3 years old; the original clutch died at 203,000 miles. The work was done by somebody else and not me (I didn't have time nor the expertise to do it, but I would not mind doing it myself: just no time to take on such a large project myself and I've never done a transmission before).
The only service that I have had done on the transmission is a drain and refill at the time of the clutch work. There are no transmission leaks that I can see and the fluid level in the transaxle (in my car the front differential and transaxle are in one case and transmission bathes them both; in automatics, they are separate) seems okay.
I am considering draining the transaxle fluid, looking at the condition of what comes out, then popping off the end cap of the transmission and seeing if there is gunk inside, and refilling the transmission case with something like Amsoil 75W-90 or maybe Redline MT90 which seems to a favorite here. I think there is regular SAE 90 in there right now.
Some of the causes which I am considering are:
* synchronizer not working
* shifter linkage
* manual fluid level
* clutch reservoir leakage
* shift fork not engaging
* internal transmission damage
What do you think?
1988 Corolla SR5 AE95
