Originally Posted by NZAE92
It's been ages since i've been on here but i need help.
My 4AF is running rough seems like it has a lumpy cam but it doesn't lol.
It runs right when its cold but when it gets warmer the idle drops and increases constantly, i've replace the gaskets between the carb and the insulator and between the insulator and the intake manifold has made a little change but is still doing the same thing,
I presumed it had an air leak somewhere or a vacuum leak, i have checked the vacuum lines on the carb and none are cracked or worn. should i just buy the genuine gaskets and replace the insulator also? I'm not sure what else it could be, i have asked the guys at my work and they say it's the gaskets still as they aren't genuine?
cheers for any feedback
Greg
I had this exact same problem on my 77 celica which probably used the same or similar carb. The problem (on mines) was an internal vacuum leak inside the carb. I ended up getting another used carb and rebuiding that one crossing my fingers in hopes that it also didn't have the problem. It didn't have the same problem so it did indeed fix it. I'm driving it to work now.
I think I figured out what was happening though. Kinda hard to explain.
1. Engine is rich when cold so vacuum leak is not apparent, (cancels out)
2. Engine warms up and is no longer rich but is now lean because of the leak
3. Engine starts to die because it's lean
4. AAC (Aux Accel Pump) squirts gas into carb because of lost vacuum (from engine dying)
5. Engine revives and runs until gas squirted in runs out. AAC is recharged
6. Repeat 3,4,5&6
Oddly enough, I looked at this thread because I'm having a similar problem on my 4AFE, but I've been holding out fixing it hoping that I'd swap the 4AGE in soon...
