Cleaning Carb? new member here! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2011, 09:53 PM   #1 (permalink)
View BeatupRolla's Photo Gallery
hi all, i just picked up the most beatin up corolla ever(body wise)..
i am trying to do some maintenance to make it run better, so far it looks like its got a leaky valve covor but i just re tightened the 3 bolts that hold the valve covor down. they seemed super loose.
my first question, is there realy only 3 bolts holding the valve covor down(3 main bolts visable from top)?
second question is can i clean the carb some how, maybe take it out? i did atempt to, i took out the old filter and replaced with a new one, old one was SUPER dirty, i had some throttle body cleaner laying around that i sprayed and wiped what i could.. but the thing is i couldnt get the black circle thing off? seems like there is some hose connected to it. so i only got the top of the carb
third and final question, is there any other simple things i can do to make this thing run better?
btw my car is the 88 corolla with i think the 4af motor
BeatupRolla is offline   Reply With Quote
Old 08-14-2011, 10:31 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
First: Yep, there is only three nuts holding down the valve cover. All it is, is a cover so anymore number of bolts is not necessary. There is a rubber gasket around the whole perimeter of the valve cover and around all four of the spark plug holes. Rubber deteriorates over time. I had an oil leakage into one of the spark plug holes before. I took the cover off, pretty anything rubber was pure fragile with the slightest touch versus anything you'd think rubber should be.
Second, obviously you know there are carb sprays and fuel additives to clean the carb. Seafoam works very well, I should add. Anyways, removing the carb is somewhat simple but you shouldn't unless it's actually problematic towards the engines' performance. If you decide to, the black air cleaner box is simple to come off. There should be a hose under it behind the carb that leads to the catalytic converter. Disconnect that and other visible connectors and it should lift off. The cables for the accelerator/ trans is pretty much straightforward. There are several vacuum lines you would need to remember where they go. If you unplug the lines from the carb and leave the other end of the lines attached to whatever they're connected to, the memory in the hoses would make it simpler as to where those lines would go. Then it'll be a matter of not forgetting a hose. With the vacuum lines taken care off, at the base of the carb, there is only 4 bolts. Remove those, the carb should lift off very easily. But keep in mind that if you do remove the carb, don't adjust any knobs, and replace the gasket where the base sits on the intake manifold.
Third, it's a very reliable engine. All I can say is keep up with the basic maintenances and it should serve you for more years and miles you'll ever travel.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
