Originally Posted by mydirtycorolla88
put a new radiator in it, put a new thermostat in it and drove it for 6 months. I noticed it was starting to over heat again and fluid was getting low so i checked for leaks found a leak changed all hoses because of it and after doing that it wont keep from over heating. After putting the new hoses in and filling the fluid all the hoses collapsed so i thought it was an air lock shut the car off opened the cap hoses opened back up and never happened again, and from there is wear i tried all the things in my first post which made this car my overheating nightmare.
Did the new radiator and thermostat solve the overheating problem for 1,2,3,4 or 5 months? Or did these new parts have no effect at all?
Is the radiator coolant level full when you check it in the morning? Is the coolant overflow jar half full
Is the coolant approximately a 50/50 mix of antifreeze and water?
When you say "FLUID FLOWS INSIDE THE RADIATOR" is that after the engine has warmed up or when the engine is cold in the morning? Or both?
