flywheel question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2011, 09:32 AM   #1 (permalink)
View thekull78's Photo Gallery
flywheel question
does anyone know how many crankbolt holes does the ae92 toyota corolla flywheel has?
thekull78 is offline   Reply With Quote
Old 08-16-2011, 09:58 AM   #2 (permalink)
Gameroom cash: $134355
4afe has 6, 4age has 8
Old 08-16-2011, 10:33 AM   #3 (permalink)
flywheel for ae92
toyotaspeed90?
ok man thanks for that help now the thing is i wanna install a lighter flywheel on my 4afe engine do you know if the 4age 8 hole flywheel will fit the 6 hole 4afe engine because all im seeing for lighter flywheels is the 4age ones (8) holes...thanks in advance
Old 08-16-2011, 10:39 AM   #4 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
no, they won't... they used to be a bunch of lightwieght 4afe flywheels on ebay. don't know who made it though
'81 BMW R65
Old 08-16-2011, 08:20 PM   #5 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I have one on my 7A-FE. At first I liked it, but now I am frustrated with it.
I need to keep the RPMs a bit higher in order to move off from a stop, without stalling, and it sounds like I am just learning to drive a stick. It is worse on a hill, and I think my clutch is suffreing for it.
If I ever need to pull the clutch, I will be re-installing the original flywheel.
I don't recommend it if you are not racing.
Anyone interested.....I have a brand new 4A-GE lightweight wheel flywheel for sale, still in the box, never installed.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 08-17-2011, 06:02 AM   #6 (permalink)
View NZAE92's Photo Gallery
AE92
http://www.vividracing.com/catalog/a...5-p-63494.html
there you go, dunno how good alluminium is withstanding that much heat and or stress.
Another way to get it lighter is to send the standard one for balancing and machining.
NZAE92 is offline   Reply With Quote
Old 08-17-2011, 12:45 PM   #7 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
I've always heard scare stories of aluminum flywheels so I'm always scared of a high RPM flywheel explosion. Especially with this car where the flywheel is directly inline with the driver.
SuperRA is offline   Reply With Quote
Old 08-17-2011, 02:56 PM   #8 (permalink)
Donald's Avatar
Both the aluminum flywheels I have, have a steel mating surface for the disk.
Old 08-17-2011, 03:25 PM   #9 (permalink)
now it's just internet myth that the aluminum flywheels break apart..... I'm sure it happens in all out drag cars but they're typically producing 1,000hp..... and at that amount of power anything can break.
I forsee other problems with aluminum flywheels that I have expressed concerns about in the past.... which has to do with steel mating surfaces, bolts, and steel starter ring gears.... their expansion rates vs. aluminum expansion rates.....
Old 08-17-2011, 03:52 PM   #10 (permalink)
Heh, well it was before the internet took off that I heard the stories, but anyhow, yea, they were still stories. Nonetheless, they don't sell scattershields for looks. And you're right, the blame isn't solely on the flywheel material being aluminum. I guess I'm just that conservative to feel that way.
