Actually, heres the catch... Gear oil isnt thicker than engine oil. 75W-90 is roughly same as 10W-40, and so on and so on. The numbers are there to differentiate gear oils and engine oils from one and other. The difference is that gear oils have EP -additives, because they're needed in gear contact. They work by increasing surface tension the more pressure is put. So when the teeth mesh, the tips dont come to contact with the sides of the sprocket teeth...Putting gear oil into an engine is foolish its not meant for it, 20W-50 would tone down noises just due to its thickness, but eventually that rod knock is going to get worse and worst case scenario is it freezes and punches a hole in the side of the block.
