This May Change My Plans... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2011, 06:22 PM   #1 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Once again, my ae92 has broken down. It started off as a slight hesitation while driving for the passed two days. Then yesterday, there was a point where it wantwd to cut off at a red light. Made it home fine. Today, started it up, bad. Put put put put put puta puta put put put puta...
Not the head gasket. Oil and coolant are fine although I found small white bead-like crap on the underside of the radiator cap. Compression tested and all cylinders seems to be within a reasonable range.
Distributor, I spent $200 but I will be returning it. Wasn't the problem. Thought I would've had intermittent sparks even though I saw sparks everytime.
Fuel, I see fuel in the carb going down the venturis. But enough? I'm not sure. My engine has always ran slightly rich.
Timing belt is definately still intact.
Last thing I could narrow it down to which I have had more problems with than anything else, the carburetor.
Here's other thungs I should mention. The air filter is somehow getting sprayed with oil. I see beads of oil droplets ON THE TOP SIDE. Which is weird. There is also a small metallic ping coming from the passenger side (cyl 1). That sound has just arised as well.
So right now, I'm stuck to decisions. As time goes, the decision will slowly narrow down. If it is fixable, nothing major, the car will be as is. If major, a motor swap for a blacktop 20v. Nonetheless, I need a car. Sep and Oct are or may be bum rides months. Nov, I have two cars I can use since my parents are out of the country for Nov. So, Nov is my best closest time for a motor swap if thats the choice. At first, before this problem, my car was gonna go to the body shop for the month but now that may change.......
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 09-20-2011, 06:53 PM   #2 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Poor oil control by piston rings or clogged up PCV valve can cause the oil on the air filter.
90 GP is offline   Reply With Quote
Old 09-20-2011, 08:20 PM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
or it's just the PCV valve spraying oil into the intake like it's designed to do... I don' think it sprays that high up the intake though...
have you checked your timing? your timing belt might have skipped a tooth or two, the same thing happened to my little brother.
'81 BMW R65
Old 09-20-2011, 08:23 PM   #4 (permalink)
SCT
iAzn
SCT's Avatar
I havent visually checked it yet. But the timing belt is new, maybe 6 momths? Ill have to see to it.
EDIT: I am told it could be a bad valve! So, I'll look further into that tomorrow night by taking off the valve cover. If it's nothing major, I'll fix it and be done with. If it's major, I may consider a blacktop swap. Blacktop, because I need parts from it for my silvertop/ blacktop turbo hybrid build.
Old 09-21-2011, 09:17 AM   #5 (permalink)
Rotary guy...
eage8's Avatar
it could be a bad valve... you should still check the timing though.
I replaced the belt on my brother's integra, and it skipped a tooth a few days later, he got a shop to re-align it and re-tighten it and it lasted a few months then started skipping teeth again. It's probably more likely this is the cause if it's new-ish.
the metallic ping is worrisome though...
sounds kind of like what happened to my 4a-f... I never did find out what was wrong with it :P
'81 BMW R65
Old 09-21-2011, 04:12 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
leakdown test would show if a valve is bad, it would also show somewhat on a compression test too.
Old 09-21-2011, 11:28 PM   #7 (permalink)
SCT
iAzn
SCT's Avatar
Yea, I need to do a leakdown. Compression test was pretty much in a reasonable range between all cylinders.
I took the valve cover off tonight and there's no visible damage to the cam lobes and the shims/lifters. All of them are nice and smooth, shiny, nothing abnormal.
I took a video with my phone. I'll post them up when I upload them onto fb or youtube.
Old 09-24-2011, 01:21 AM   #8 (permalink)
SCT
iAzn
SCT's Avatar
AE92
There ya go.
Until I find out where or what is making that sound, whether it's fixable or not would determine me fixing it OR Blacktop 20V.
(Yes, I do have a Silvertop 20V but that's my project motor which is all torn apart right now.)
Old 09-25-2011, 05:52 PM   #9 (permalink)
ayang951's Avatar
Gameroom cash: $163050
View ayang951's Photo Gallery
hrm... sounds like you need a valve job maybe... not too sure, but my last sedan had a problem like that, and it needed the valves to be readjusted, you checked the timing yet? it prolly skipped a teeth as well...
"I live my life one corner at a time, for those few seconds or less, im free."
~Mr.Yang
http://www.toyotanation.com/forum/sh...=1#post3365798
ayang951 is offline   Reply With Quote
Old 10-06-2011, 02:40 AM   #10 (permalink)
SCT
iAzn
SCT's Avatar
Been working. This past weekend, I had a three-day weekend. But it was all rainy and cold. So I finally got around today to look at the timing belt. Here's what I've found:
Old 10-06-2011, 08:50 AM   #11 (permalink)
ayang951's Avatar
amazing.....
~Mr.Yang
Old 10-06-2011, 02:23 PM   #12 (permalink)
SCT
iAzn
SCT's Avatar
Yea, cant really figure out why the slot in the timing gear wore out like that. Unless there was an issue prior.
Old 10-06-2011, 03:13 PM   #13 (permalink)
ayang951's Avatar
im still amazed when i look at it... can i say... that finally the belt won and not the gears this time...
~Mr.Yang
Old 10-06-2011, 03:15 PM   #14 (permalink)
Rotary guy...
eage8's Avatar
is that the one you got from me? that's crazy....
it did have about 220k on it before you got it :-P
'81 BMW R65
Old 10-06-2011, 04:55 PM   #15 (permalink)
new sr5 guy
sincity.rolla's Avatar
View sincity.rolla's Photo Gallery
wow. i keep looking at the picture and it doesnt sink in..
another 89 sr-5.....
89 corolla sr5 5spd. rip
06-elantra, wifes car
88-mr2...rip
88-corolla gts...sold
sincity.rolla is offline   Reply With Quote
