is my exhaust over heating my car?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2011, 10:17 PM   #1 (permalink)
sr5 tuner
View sbcherokee's Photo Gallery
the tube that goes from the catalytic converter to the air cleaner is making my car over heat.... i do not know why ... any ideas on what may be causing this? the motor is a 2bbl 4af in a 88 sr5 coupe
sbcherokee is offline   Reply With Quote
Old 09-24-2011, 12:46 AM   #2 (permalink)
View eberbs1's Photo Gallery
I have had that hose plugged for 2 years and never had an issue.
eberbs1 is offline   Reply With Quote
Old 09-24-2011, 03:39 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I would doubt so the tube doesnt go from cat to air clenaer, rather from air cleaner to cat. Its an air injection system that flows fresh air into the cat to make it work properly, plugging it can cause other issues.
Your overheating is something else, I would check the cooling system.
Old 09-25-2011, 05:42 PM   #4 (permalink)
ayang951's Avatar
Gameroom cash: $163050
View ayang951's Photo Gallery
look into the thermostat, the water pump hose in the rear of the motor and the heater core and hoses... that might be your culprit, i had one of those symptoms on my car, it over heated once, looked at it, and it was the water pump hose in the rear, so i replaced all of them including the water pump, i spent about $80 on all parts new and installed...
"I live my life one corner at a time, for those few seconds or less, im free."
~Mr.Yang
http://www.toyotanation.com/forum/sh...=1#post3365798
ayang951 is offline   Reply With Quote
Old 09-25-2011, 10:35 PM   #5 (permalink)
sr5 tuner
i have search all these and replaced every cooling system part possible. that pipes blowin hot air into the carb and the overheat is not showing on the gauge... the reason i know it is it, is because i unhooked it and the problem stopped its very confusing
Old 09-26-2011, 11:35 AM   #6 (permalink)
sr5 tuner
could it be that something has clogged the converter without my knowing and the exhaust is coming out of that pipe? the car runs alot better with that hose so i wld really like it hooked up
Old 09-26-2011, 11:55 AM   #7 (permalink)
ayang951's Avatar
hrm, idk then... i have never owned a carb 4af before...
~Mr.Yang
Old 09-26-2011, 12:05 PM   #8 (permalink)
RIBMIESTER
JimBowNut's Avatar
Gameroom cash: $135801
View JimBowNut's Photo Gallery
Well Cats do clog up and have to be replaced sometimes..........Take your Cat off and run a 'TEST PIPE' to see if that is the real problem........Sometimes the exhaust manifold will glow red at when you look at it at night.........Idk, take a look at that first.?
'(glows red when clogged)'
A BLAST FROM MY PAST, MAN, THE FUN WE HAD!
JimBowNut is offline   Reply With Quote
