speedometer issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2011, 07:46 PM   #1 (permalink)
View merrittr's Photo Gallery
Canada speedometer issue
Hi My speedometer on my 1990 corolla is acting old it wobbles a round and is unstable , how do i get at the clock work which seems to be flakey
merrittr is offline   Reply With Quote
Old 10-02-2011, 09:53 PM   #2 (permalink)
rdyzz's Avatar
Gameroom cash: $137500
View rdyzz's Photo Gallery
well if its the speedo i wouldnt dink around with it, rather id just replace it with one from a junkyard. this might be the case also, i've notice the speedo becomes somewhat funny when the speedo cable is near worn out or about to break. it's not for sure, but i've had this happen to me 3 times in 3 different cars i've owned, where the speedo becomes funny and jumpy. then weeks later the speedo stops working altogether, and usually is the cable being broken. this is also a gear in the tranny that connects to the differential, but usually its the cable.
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
rdyzz is offline   Reply With Quote
Old 10-03-2011, 04:29 AM   #3 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Unscrew the connection on speedo cable( in engine compartment) and put some lube in both sections of cable to see if that helps.
90 GP is offline   Reply With Quote
Old 10-03-2011, 05:41 AM   #4 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
For me, it was the speedo unit within the instrument cluster that was faulty. The thing the cable goes into was flunking up. Swapping those out are very simple. You'll just need to dial up the mileage to match.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
The Following User Says Thank You to SCT For This Useful Post:
merrittr (10-03-2011)
Old 10-03-2011, 08:00 PM   #5 (permalink)
Cool advice guys , still some questions . Was at the junk yard got the cluster all unscrewed but couldnt gain access to the back to detach the speedo ... is there a trick?
Old 10-03-2011, 09:24 PM   #6 (permalink)
plyr503's Avatar
View plyr503's Photo Gallery
Detach the speedo cable from the transmission before you attempt to pull the cluster from the dash. If i remember right theres not much slack in the speedo cable so doing this ought to give you the slack you need to pull the cluster and get to the speedo connection behind said cluster.
plyr503 is offline   Reply With Quote
Old 10-04-2011, 09:13 PM   #7 (permalink)
Great thanks I will try that
