Brake Light Switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2011, 01:50 AM   #1 (permalink)
View eishiba's Photo Gallery
Brake Light Switch
I have a 91 corolla same old same old. I bled the brakes and I am going to assume the brake light switch is jammed or something because even with the car off, the brake lights will stay on. One must unplug the battery to turn them off. What can I do?
eishiba is offline   Reply With Quote
Old 10-08-2011, 04:48 AM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
Duck down to the brake pedal and the switch is right there on the brake pedal. I had this happen to me once. For me, it was a rubber piece that came off the pedal lever so the button never stayed depressed to keep the brake lights from cutting off when I wasnt on the brakes...... my fix was using a button I got off my old JROTC jacket... and still there!
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 10-09-2011, 03:10 PM   #3 (permalink)
I found the switch but the brake pedal isn't pushing the switch in all the way.
Old 10-09-2011, 06:17 PM   #4 (permalink)
View eberbs1's Photo Gallery
there is an adjusting bolt on the brake switch that you loosen and that allows you to screw the brake switch further into the threads it sits in to adjust its release point, when you got it where you want it just tighten the blot back up and your good to go.
and it is easier to turn the brake switch with the plug leading to it dissconnected.
Hope this helps.
eberbs1 is offline   Reply With Quote
