4af stuck choke when start up?
so i had problems with cold starts, it would not start up right away but usualy on second and third time but even after it starts it would sputter and die unless i hold the gas.
i found a way to fix this problem by simply pressing in the gas pedel 3 times, then the car starts up perfectly, no sputtering and dieing. the rpms would jump up to around 2000-3000 rpms like normal but the thing is once the car is warm up it doesnt go back to around 1000 rpms like it should. this makes me beleive i have a stuck choke?? i did unplug the aux acceleration pump since i was getting a gas smell when the car was off.
i now beleive that the choke is stuck? not sure if its the choke that brings the rpms up to 2000-3000 rpms when cold, but whatever that triggers the rpms to jump up must be stuck or something..
