Tps secret - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2011, 05:25 PM   #1 (permalink)
View strikefalcon's Photo Gallery
Tps secret
What is the key to disconnecting the Throttle Position Sensor on my 92 4AFE? I only ask as I would like to reconnect it later. lol
Thanks
strikefalcon is offline   Reply With Quote
Old 10-12-2011, 07:56 PM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
I'm not sure of my memory, but if it's the connector with a metal wire clip, then you have to remove that by picking it out with a small screwdriver etc.and then the connector will separate from the TPS. When the connector is off the TPS you can put the metal wire clip back on the connector and when you are ready to re-connect, you just push it on and it should lock automatically.
SuperRA is offline   Reply With Quote
The Following User Says Thank You to SuperRA For This Useful Post:
strikefalcon (10-12-2011)
Old 10-12-2011, 08:52 PM   #3 (permalink)
Ok remove clip and disconnect. thanks
