If the top timing cover is properly installed, you have to lift the valve cover to get it off. One of those while-your-at-it-you-might-as-well things is to check the valve clearances with a feeler gage. When you replace the valve cover, remember to put silicone sealant a the base of the arches in the valve cover. If you rely only on the rubber gasket to seal, you will get a slow oil leak at those places. If the three washers under the nuts that hold the timing cover are in bad shape, it's a good idea to use silicone sealant on them also.
An impact wrench is the handiest tool for removing the crankshaft pulley. You may need a puller to get it all the way off. On the 4AFE the crankshaft pulley is partly hard rubber, which can deteriorate, so you should inspect it.
