Oil Filter Unscrewing itself - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2011, 03:18 AM   #1 (permalink)
View eberbs1's Photo Gallery
Canada Oil Filter Unscrewing itself
The last few weeks i noticed that my corolla was leaking more oil than normal.
Today after work i go to check my oil (check it every 1-2 days) and it was dry stick! I added oil and started the motor and right away i see smoke, it was oil dripping off the oil pan onto the exaust (lots of oil dripping) I followed the trail back to the oil filter and find that the oil filter is 2 full turns loose!!
Tightened it back up and away i go.
Has anyone had this happen or knows of this happening? I change my oil all the time and have never had this issue.
Next week I hope to replace the oil pan gasket, timing belt, water pump and crank oil seal and hope that will stop some of the other oil leaks.
For 350k km and no paper work for a timing belt change I think its about time (and i have all the paper work of all the work on the car from both PO's and no timing belt).
eberbs1 is offline   Reply With Quote
Old 10-28-2011, 04:39 AM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
I've noticed my oil filter would loosen up but never that loose. Just loose enough for a drip here and there. Then I just tighten it back up.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 10-28-2011, 08:58 AM   #3 (permalink)
View yamahaSHO's Photo Gallery
Try running it down tighter next time. I have the opposite problem when I do an oil change... I struggle to take it off. Honestly, I put them on as tight as I can with my hand. I run out of grip before having any seal issues with too much compression.
yamahaSHO is offline   Reply With Quote
Old 10-28-2011, 12:07 PM   #4 (permalink)
Gameroom cash: $134355
MAN UP AND TIGHTEN IT.... it's only like one of the most important things on you engine....
Old 10-28-2011, 01:36 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Maybe you got the wrong filter there. Theres some thread variance between few filters, some metric threaded filters will engage on imperial threads and feel like it tightens, but will loosen up just like you discribed.
Common problem with Nissan SR20 engines, because they've been made with both types of threads
Old 10-28-2011, 03:20 PM   #6 (permalink)
RogueMoog's Avatar
Gameroom cash: $314030
View RogueMoog's Photo Gallery
When I put in a new oil filter, I pretty much follow the directions on the package and never had a problem. Hand-tighten til it contacts the block, then 3/4 of a turn.
RogueMoog is online now   Reply With Quote
Old 10-28-2011, 03:25 PM   #7 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
you can certainly go tighter. shoot, almost every single new car from the factory has the oil filter on so damn tight that it can be a real PIA to get off. you can at least tighten it till you are struggling a bit.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is online now   Reply With Quote
Old 10-28-2011, 04:26 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
No you cant tighten it too hard, when you do so, the seal will twist and cause it to leak.
Old 10-28-2011, 04:41 PM   #9 (permalink)
Like RogueMoog I follow the directions on the box.
Also i have used this same brand of oil filter the last few changes and have never had this problem.
Old 10-28-2011, 09:26 PM   #10 (permalink)
RogueMoog's Avatar
Did the rubber seal from a previous filter stick to the block? That might cause it to leak, having two of them stacked up. I've found the rubber ring stuck a few times when changing the oil, on different cars.
