4AFE issues ae92 corolla
Hi I'm pretty new here, I've been lurking for quite a bit so I thought why not start a thread and get some service advice about my car.
I've got a 1993 AE92R Corolla sedan with a 4A-FE 5 speed manual.
It's got records showing its been serviced every 10,000 until 130,000 but between 130,000 and 192,000 (when I bought it) there are no records. Its currently at 220,000 and all I've managed to get done so far is oil change, oil filter change, spark plugs and a cold air intake. It's running a lot better now but I'm sure there are a quite a few things that need replacing considering the time between servicing. I'm pretty new to cars but I'm learning!
Timing belt was done at 130,000, I'm guessing its time to change that and the water pump too? Besides that I've noticed a few things that to me come across odd,
When I turn on the car in the morning for a few minutes the car gives a sort of grinding sound, its subtle but just doesn't sound right to me. Goes away once the car has a few mins warming up but not at operating temp.
My clutch slips when trying to shift not necessairly at too high RPM but usually if I try to shift and acelerate too quickly. Only occurs if I'm being too agressive. Not sure if thats something to worry about though.
My idle sits at between 1800-2200 until warm and then its 800-900. Which is normal but that said when I drive and the temp gauge goes below mid rage my idle increases to the 1500rpm mark until the gauge is at normal. Is this normal?
My leads say "1993 SUMITOMO" I'm assuming they're nearly 20 years old? the service history doesn't list replacement leads either. Time to change them maybe?
Anyway any help would be appreciated!
AE93 '90 Corolla SX Seca
4A-GE
AE92R '93 Corolla Sedan
4A-FE
