Fans stay on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2011, 04:33 PM   #1 (permalink)
View pawesome's Photo Gallery
Fans stay on
I have a 90 efi corolla, both my radiator and ac fans will stay on when the key is turned to on. ive read a few threads and have seen people say its the relay/fan switch/sender/sensor. can anybody tell me how i could test these things to figure out what is really causing the problem. I have found the relay/the sender and sensor on the thermo housing and what look like two additional temp sensors.
car is completely stock, new battery, ac is not on,new coolant, on cold engine
pawesome is offline   Reply With Quote
Old 11-07-2011, 06:13 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
The radiator fan is "fail safe on", and it's circuit runs through the A/C high/low pressure switch.
If there is a break in the circuit, (including a bad fan thermo switch) the radiator fan will stay on.
The fact that the A/C fan is on also, makes me think that the A/C high/low switch is bad.
The radiator fan switch is the one that hs the white connector with one wire in the last photo.
The A/C high/low pressure switch is over on the right side of the engine bay on the A/C pipe just forward of the firewall.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
The Following User Says Thank You to Donald For This Useful Post:
pawesome (11-08-2011)
Old 11-07-2011, 10:55 PM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
in the second picture there is nothing hooked up to that coolant sensor... I don't think that's actually a sensor for the radiator fan, but I would definitely fix it.
'81 BMW R65
The Following User Says Thank You to eage8 For This Useful Post:
Old 11-08-2011, 01:52 PM   #4 (permalink)
which of these two would be the high/low switch? how could i test it to see if that's causing the problem, thanks.
was disconnected so i could clean it up for the picture but thanks
Old 11-08-2011, 03:13 PM   #5 (permalink)
Donald's Avatar
I believe it is the on on the larger diameter line, but am not sure. I would need to check the manual. Will try and do that later.
Right now I need to make the most of the good weather to continue with stripping my wrecked car.
pawesome (11-13-2011)
Old 11-13-2011, 02:34 PM   #6 (permalink)
bump
Old 11-14-2011, 01:31 PM   #7 (permalink)
Donald's Avatar
The Dual pressure switch is on the larger diameter line. The high pressure switch is on the smaller line.
I will scan the page with the test procedure when I figure out what is wrong with my scanner. If not I will write the instructions, but bare with me. I've been really busy.
Old 11-14-2011, 04:35 PM   #8 (permalink)
Donald's Avatar
PM sent
Old 11-15-2011, 07:32 PM   #9 (permalink)
blb
View blb's Photo Gallery
Donald is correct about the "fans on" issue being the result of the fail safe electrical design of the fan circuit. Any open circuit in the fan wiring can cause this issue.
In my experience, its usually either a bad connection to the coolant temperature sensor or a bad connection in the fan harness connector located below the battery tray. I usually just disconnect the connector located below the battery tray, clean the contacts, reconnect the two halves of the connector and the problem is solved.
blb is offline   Reply With Quote
Old 11-16-2011, 07:43 PM   #10 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
90% of the time, the fans stay on because the thermostat is shot... have you tried a new one yet?
Old 11-16-2011, 07:52 PM   #11 (permalink)
Donald's Avatar
You mean "thermo switch" (fan switch) right? Not "thermostat".
