Cleaning my gas tank - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2011, 12:20 AM   #1 (permalink)
View Rod K's Photo Gallery
Gen6 Cleaning my gas tank
Now this isn't the usual run of the mill clean my tank story. I had my tank's drain plug replaced and I was cleaning it's outsides and I was ready to install it when I looked into the bottom inside the tank. It has a fine dust on the bottom inside the tank, I mean dust not a phospahte coating from the repair process good old actual dirt. Since I've just gone through the fuss and bother or replaceing my fuel filter I have not urge to to that all again. Any ideas on what to use to swish and clean out the dirt (not rust, the thing is clean, just dusty) the pump had died that is why it was apart. All I want to do is clean the thing up again. I've read about using radiator cleaner and hot water, agitate it and rinse it all out, pour in methyl hydrate to disperse the water then when dry, install. OR Does anyone have any better ideas? As to Cleaning up the inside? I can't reach all the areas with my hand due to all the baffles inside as is is the fuel injected 1991 corolla tank. I'm almost close enough to be finished and then something else comes up like this. No point going back to the people who screwed it up, I doubt they'd improve it.
Rod K is offline   Reply With Quote
Old 11-08-2011, 11:45 AM   #2 (permalink)
teh pwnager
View Rabbitbunny's Photo Gallery
Don't bother. A new tank is about $70 delivered on eBay.
Alternatively, I used muriatic acid and a coating kit to great success on a Malibu once. I believe it was Rustoleum, but I know it was a little plastic box.
Rabbitbunny is offline   Reply With Quote
Old 11-08-2011, 08:10 PM   #3 (permalink)
Well I am 99.9% finished and it is a Japanese tank which is different from the USA ones and I don't want to get stuck fabricating. I just want to gte the shop dust out.
Old 11-08-2011, 08:39 PM   #4 (permalink)
ayang951's Avatar
Gameroom cash: $163050
View ayang951's Photo Gallery
good old swash of gasoline might do the trick... i mean i have never cleaned one before, but thats what i would think about... then later use the gas from the tank and start a fire in the pit... but im just smh on this though.... =D
"I live my life one corner at a time, for those few seconds or less, im free."
~Mr.Yang
http://www.toyotanation.com/forum/sh...=1#post3365798
ayang951 is offline   Reply With Quote
Old 11-09-2011, 05:53 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
You have a pre filter on your fuel pump anyways, which is actually quite good. I'd probably just put the tank as is, or if I'm really worried, some kerosene and flush it out.
I havent seen any difference between EFI tanks, except the japanese tank makes stealing gasoline easy as pie as it has a drain plug.
Old 11-10-2011, 10:48 AM   #6 (permalink)
Blof-fan's Avatar
Gameroom cash: $294850
View Blof-fan's Photo Gallery
There is a difference though. You might not expect it (I didn't) but the coupé tank is different than the other tanks. Don't recall what it was. It had something to do with the flanges. I believe there was one extra or they were a different size or something like that.
A friend of mine acctually ordered a new tank for his Liftback, but I believe that the flange for the fillertube was different and thus didn't fit.
Driving : '92 Toyota T19 Carina E GTi
Repairing : '92 Toyota AE92 Corolla Hatchback GTSi
Restoring : '88 Toyota AE92 Corolla Coupé GT-S
My personal website: http://www.corollaae92gts.nl
Blof-fan is online now   Reply With Quote
