Ae91 Exhaust write up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2011, 12:39 AM   #1 (permalink)
Inagawa's Avatar
View Inagawa's Photo Gallery
Gen6 Ae91 Exhaust write up
This is for the sedan's with the 4af/4afe equipped engine's. But can take a few pointer's if need.
well for basic's, here's info on performance exhaust in general..
Some say that "an engine needs backpressure to work correctly." Is this true?
No. It would be more correct to say, "a perfectly stock engine that cannot adjust its fuel delivery needs backpressure to work correctly." This idea is a myth. As with all myths, however, there is a hint of fact with this one. Particularly, some people equate backpressure with torque, and others fear that too little backpressure will lead to valve burning.
The first reason why people say "backpressure is good" is because they believe that increased backpressure by itself will increase torque, particularly with a stock exhaust manifold. Granted, some stock manifolds act somewhat like performance headers at low RPM, but these manifolds will exhibit poor performance at higher RPM. This, however does not automatically lead to the conclusion that backpressure produces more torque. The increase in torque is not due to backpressure, but to the effects of changes in fuel/air mixture, which will be described in more detail below.
The other reason why people say "backpressure is good" is because they hear that cars (or motorcycles) that have had performance exhaust work done to them would then go on to burn exhaust valves. Now, it is true that such valve burning has occurred as a result of the exhaust mods, but it isn't due merely to a lack of backpressure.
The internal combustion engine is a complex, dynamic collection of different systems working together to convert the stored power in gasoline into mechanical energy to push a car down the road. Anytime one of these systems are modified, that mod will also indirectly affect the other systems, as well.
Now, valve burning occurs as a result of a very lean-burning engine. In order to achieve a theoretical optimal combustion, an engine needs 14.7 parts of oxygen by mass to 1 part of gasoline (again, by mass). This is referred to as a stochiometric (chemically correct) mixture, and is commonly referred to as a 14.7:1 mix. If an engine burns with less oxygen present (13:1, 12:1, etc...), it is said to run rich. Conversely, if the engine runs with more oxygen present (16:1, 17:1, etc...), it is said to run lean. Today's engines are designed to run at 14.7:1 for normally cruising, with rich mixtures on acceleration or warm-up, and lean mixtures while decelerating.
Getting back to the discussion, the reason that exhaust valves burn is because the engine is burning lean. Normal engines will tolerate lean burning for a little bit, but not for sustained periods of time. The reason why the engine is burning lean to begin with is that the reduction in backpressure is causing more air to be drawn into the combustion chamber than before. Earlier cars (and motorcycles) with carburetion often could not adjust because of the way that backpressure caused air to flow backwards through the carburetor after the air already got loaded down with fuel, and caused the air to receive a second load of fuel. While a bad design, it was nonetheless used in a lot of vehicles. Once these vehicles received performance mods that reduced backpressure, they no longer had that double-loading effect, and then tended to burn valves because of the resulting over-lean condition. This, incidentally, also provides a basis for the "torque increase" seen if backpressure is maintained. As the fuel/air mixture becomes leaner, the resultant combustion will produce progressively less and less of the force needed to produce torque.
Modern BMWs don't have to worry about the effects described above, because the DME (car's computer) that controls the engine will detect that the engine is burning leaner than before, and will adjust fuel injection to compensate. So, in effect, reducing backpressure really does two good things: The engine can use work otherwise spent pushing exhaust gas out the tailpipe to propel the car forward, and the engine breathes better. Of course, the DME's ability to adjust fuel injection is limited by the physical parameters of the injection system (such as injector maximum flow rate and fuel system pressure), but with exhaust backpressure reduction, these limits won't be reached.
- Adapted from Thomas V.
here's another exhaust theory..
We've seen too much misinformation regarding exhaust theory. What kind of misinformation? For starters, there are a lot of people in the "Bigger is Better" camp. We're talking about exhaust pipe diameters. Even the big magazine editors are boldly smattering statements like, "For a turbo car, you can't get an exhaust pipe that's too big." Also, terms like "back pressure" and the statement, "An engine needs back pressure to run properly!" really rub us the wrong way.
Let's start from the beginning. What is an exhaust system? Silly question? Not hardly. Exhaust systems carry out several functions. Among them are: (1) Getting hot, noxious exhaust gasses from your engine to a place away from the engine compartment; (2) Significantly attenuating noise output from the engine; and (3) In the case of modern cars, reduce exhaust emissions.
Hardware
In order to give you a really good idea of what makes up an exhaust system, let's start with what exhaust gas travels through to get out of your car, as well as some terms and definitions:
After your air/fuel mixture (or nitrous/fuel mixture) burns, you will obviously have some leftovers consisting of a few unburned hydrocarbons (fuel), carbon monoxide, carbon dioxide, nitrogen oxides, sulfur dioxide, phosphorus, and the occasional molecule of a heavy metal, such as lead or molybdenum. These are all in gaseous form, and will be under a lot of pressure as the piston rushes them out of the cylinder and into the exhaust manifold or header. They will also be hotter 'n Hades. (After all, this was the explosion of an air/fuel mixture, right?) An exhaust manifold is usually made of cast iron, and its' primary purpose is to funnel several exhaust ports into one, so you don't need four exhaust pipes sticking out the back of your Civic.
Exhaust manifolds are usually pretty restrictive to the flow of exhaust gas, and thus waste a lot of power because your pistons have to push on the exhaust gasses pretty hard to get them out. So why does virtually every new automobile sold have exhaust manifolds? Because they are cheap to produce, and easy to install. Real cheap. Real easy. Like me.
"Ok," you ask, "so now what?" Ah, good thing you asked. The performance alternative to the exhaust manifold is a header. What's the difference? Where a manifold usually has several holes converging into a common chamber to route all your gasses, a header has precisely formed tubes that curve gently to join your exhaust ports to your exhaust pipe. How does this help? First of all, as with any fluid, exhaust gasses must be treated gently for maximum horsepower production. You don't want to just slam-bang exhaust gas from your engine into the exhaust system. No way, Jo-se'! Just as the body of your '94 Eclipse is beautiful, swoopy, and aerodynamic, so must be the inside of your exhaust system.
Secondly, a header can be "tuned" to slightly alter your engines' characteristics. We'll go in-depth into header tuning a little later.
Nextly, exhaust gasses exit from your manifold or header, travel through a bit of pipe, then end up in the catalytic converter, or "cat". The cat's main job is to help clean up some of the harmful chemicals from your exhaust gas so they don't end up in your lungs. In most cars, they also do a great job of quieting things down and giving any exhaust system a deeper, mellow tone. You'll see a lot of Self-Proclaimed Master Technicians (SPMT's) telling people that removing a cat will get you tons of power. There's room for debate on this, but in our experience, removing a catalytic converter from a new car won't gain you much in the horsepower department. It can also get you a $1500 fine if the EPA finds out! If you drive an OBD-II equipped car, you'll also get that damn annoying CHECK ENGINE light burnin' up your dashboard. (And for all you racers concerned with OBD-II's fabled "limp mode", you can put your fears to rest.)
From the catalytic converter, the exhaust gasses go through a bit more pipe and then into a muffler, or system consisting of several mufflers and/or resonators.
Are you a muff?
Exhaust gases leave the engine under extremely high pressure. If we allowed exhaust gasses escape to the atmosphere directly from the exhaust port, you can well imagine how loud and cop-attracting the noise would be. For the same reason gunshots are loud, engine exhaust is loud. Sure, it might be cool to drive around on the street with that testosterone producing, chest-thumping, 150 decibel roar coming from your car… for about 5.3 seconds. (Not 5.2 or 5.4 seconds… 5.3.) Even the gentleman's gentleman has gotta use a muffler, or system of mufflers, on their exhaust.
Again, you may hear a few SPMT's tell you that "Borla mufflers make horsepower!" Or "An engine needs some backpressure to run properly!" Nonsense. A muffler can no more "make" horsepower than Wile E. Coyote can catch roadrunners. Any technician with any dyno experience will tell you that the best mufflers are no mufflers at all!
Types of Muff
Mufflers can take care of the silencing chores by three major methods: Absorption, Restriction, and Reflection. Mufflers can use one method, or all three, to attenuate sound that is not so pleasing to the ears of the Highway Patrol.
The absorption method is probably the least effective at quelling engine roar, but the benefit is that "absorbers" are also best at letting exhaust gas through. Good examples of absorbers are the mufflers found in GReddy BL-series exhausts, DynoMax UltraFlow, and the good old-fashioned Cherry Bomb glasspack.
Absorption mufflers are also the simplest. All of the above named mufflers utilize a simple construction consisting of a perforated tube that goes through a can filled with a packing material, such as fiberglass or steel wool. This is similar to simply punching holes in your exhaust pipe, then wrapping it up with insulation. Neat, huh?
Another trick absorption mufflers use to kill off noise is, well, tricky. For example, the Hooker Aero Chamber muffler is a straight-through design, with a catch. Instead of a simple, perforated tube, there is a chamber inside the muffler that is much larger than the rest of the exhaust pipe. This design abates sound more efficiently than your standard straight-through because when the exhaust gasses enter this large chamber they slow down dramatically. This gives them more time to dwell in the sound insulation, and thus absorb more noise. The large chamber gently tapers back into the smaller size of your exhaust pipe, and the exhaust gasses are sent on their merry way to the tailpipe.
Restriction
Doesn't that word just make your skin crawl? It's right up there in the same league with words like "maim" and "rape".
Obviously, a restrictive muffler doesn't require much engineering expertise, and is almost always the least expensive to manufacture. Thus, we find restrictive mufflers on almost all OEM exhaust systems. We won't waste much time on the restrictive muffler except to say that if you got 'em, you might not want to flaunt 'em.
Reflection
Probably the most sophisticated type of muffler is the reflector. They often utilize absorption principles in conjunction with reflection to make the ultimate high-performance silencer. Remember any of your junior high school math? Specifically, that like numbers cancel each other when on a criss-cross? That's the same principal used by the reflective muffler. Sound is a wave. And when two like waves collide, they will "cancel" each other and leave nothing to call a corpse but a spot of low-grade heat.
There are numerous engineering tricks used in the reflective muffler. Hedman Hedders makes a muffler that looks a lot like a glasspack. In fact, it is a glasspack with a catch. The outer casing is sized just-so, so that high-pitched engine sound (what we deem "noise") is reflected back into the core of the muffler… where those sound waves meet their maker as they slam right into a torrent of more sound waves of like wavelength coming straight from the engine. And, this muffler is packed with a lot of fiberglass to help absorb any straggling noise that might be lagging behind.
The Exhaust Pulse
To gain a more complete understanding of how mufflers and headers do their job, we must be familiar with the dynamics of the exhaust pulse itself. Exhaust gas does not come out of the engine in one continuous stream. Since exhaust valves open and close, exhaust gas will flow, then stop, and then flow again as the exhaust valve opens. The more cylinders you have, the closer together these pulses run.
Keep in mind that for a "pulse" to move, the leading edge must be of a higher pressure than the surrounding atmosphere. The "body" of a pulse is very close to ambient pressure, and the tail end of the pulse is lower than ambient. It is so low, in fact, that it is almost a complete vacuum! The pressure differential is what keeps a pulse moving. A good Mr. Wizard experiment to illustrate this is a coffee can with the metal ends cut out and replaced with the plastic lids. Cut a hole in one of the lids, point it toward a lit candle and thump on the other plastic lid. What happens? The candle flame jumps, then blows out! The "jump" is caused by the high-pressure bow of the pulse we just created, and the candle goes out because the trailing portion of the pulse doesn't have enough oxygen-containing air to support combustion. Neat, huh?
Ok, now that we know that exhaust gas is actually a series of pulses, we can use this knowledge to propagate the forward-motion to the tailpipe. How? Ah, more of the engineering tricks we are so fond of come in to play here.
Just as Paula Abdul will tell you that opposites attract, the low pressure tail end of an exhaust pulse will most definitely attract the high-pressure bow of the following pulse, effectively "sucking" it along. This is what's so cool about a header. The runners on a header are specifically tuned to allow our exhaust pulses to "line up" and "suck" each other along! Whoa, bet you didn't know that! This brings up a few more issues, since engines rev at various speeds, the exhaust pulses don't always exactly line up. Thus, the reason for the Try-Y header, a 4-into-1 header, etc. Most Honda headers are tuned to make the most horsepower in high RPM ranges; usually 4,500 to 6,500 RPM. A good 4-into-1 header, such as the ones sold by Gude, are optimal for that high winding horsepower you've always dreamed of. What are exhaust manifolds and stock exhaust systems good for? Besides a really cheap boat anchor? If you think about it, you'll realize that since stock exhausts are so good at restricting that they'll actually ram the exhaust pulses together and actually make pretty darn good low-end torque! Something to keep in mind, though, is that even though an OEM exhaust may make gobs of low-end torque, they are not the most efficient setup overall, since your engine has to work so hard to expel those exhaust gasses. Also, a header does a pretty good job of additionally "sucking" more exhaust from your combustion chamber, so on the next intake stroke there's lots more fresh air to burn. Think of it this way: At 8,000 RPM, your Integra GS-R is making 280 pulses per second. There's a lot more to be gained by minimizing pumping losses as this busy time than optimizing torque production during the slow season.
General Rules of Thumb with Headers
You will undoubtedly see a variety of headers at your local speed shop. While you won't be able to determine the optimal power range of the headers by eyeballing them, you'll find that in general, the best high-revving horsepower can be had with headers utilizing larger diameter, shorter primary tubes. Headers with smaller, longer primaries will get you
slightly better fuel economy and better street driveability. With four cylinder engines, these are also usually of the Tri-Y design, such as the DC Sports and Lightspeed headers.
Do Mufflers "Make" Horsepower?
The answer, simply, is no. The most efficient mufflers can only employ the same scavenging effect as a header, to help slightly overcome the loss of efficiency introduced into the system as back pressure. But I have yet to see an engine that made more power with a muffler than an open header exhaust. "So," you ask, "what the hell is the best flowing muffler I can buy?"
According to the flowbench, two of the best flowing units you can buy are the Walker Dyno Max and the Cyclone Sonic. They even slightly out flow the straight through designs from HKS and GReddy BL series. Amongst the worst, are the Thrush Turbo and Flow Master mufflers. We'll flow some of the newer mufflers as they become available at our local Chief auto.
Resonators
On your typical cat-back exhaust system, you'll see a couple of bulges in the piping that are apparently mini-mufflers out to help the big muffler that hangs out back. These are called Helmholtz Resonators and are very similar to glasspacks. The main difference is that firstly, there is no sound-absorbing fiberglass or steel wool in a Resonator. And secondly, their main method of silencing is the reflective principle, not absorption. An easy way to tell the difference between a glasspack and a true Helmholtz Resonator is to "ping" one with your finger. A glasspack will make a dull thud, and a true Resonator will make a clear "ping!" sound.
Turbos
Another object that might be sitting in your exhaust flow is a turbine from a turbocharger. If that is the case, we envy you.
Not only that, but turbos introduce a bit of backpressure to your exhaust system, thus making it a bit quieter. All of the typical scavenging rules still apply, but with a twist. Mufflers work really well now! Remember, one of the silencing methods is restriction, and a turbine is just that, a restriction.
This is actually where the term "turbo muffler" is coined. Since a turbine does a pretty good job of silencing, OEM turbo mufflers can do a lot less restricting to quiet things down. Of course, aftermarket manufacturers took advantage of this performance image and branded a lot of their products with the "turbo" name in order to drum up more business from the high performance crowd. We're sad to say that the term "turbo" has been bastardized in this respect, and would like that to serve as a warning. A "turbo" muffler is not necessarily a high-performance muffler.
Pipe Sizing
We've seen quiet a few "experienced" racers tell people that a bigger exhaust is a better exhaust. Hahaha… NOT.
As discussed earlier, exhaust gas is hot. And we'd like to keep it hot throughout the exhaust system. Why? The answer is simple. Cold air is dense air, and dense air is heavy air. We don't want our engine to be pushing a heavy mass of exhaust gas out of the tailpipe. An extremely large exhaust pipe will cause a slow exhaust flow, which will in turn give the gas plenty of time to cool off en route. Overlarge piping will also allow our exhaust pulses to achieve a higher level of entropy, which will take all of our header tuning and throw it out the window, as pulses will not have the same tendency to line up as they would in a smaller pipe. Coating the entire exhaust system with an insulative material, such as header wrap or a ceramic thermal barrier coating reduces this effect somewhat, but unless you have lots of cash burning a hole in your pocket, is probably not worth the expense on a street driven car.
Unfortunately, we know of no accurate way to calculate optimal exhaust pipe diameter. This is mainly due to the random nature of an exhaust system -- things like bends or kinks in the piping, temperature fluctuations, differences in muffler design, and the lot, make selecting a pipe diameter little more than a guessing game. For engines making 250 to 350 horsepower, the generally accepted pipe diameter is 3 to 3 � inches. Over that amount, you'd be best off going to 4 inches. If you have an engine making over 400 to 500 horsepower, you'd better be happy capping off the fun with a 4 inch exhaust. Ah, the drawbacks of horsepower. The best alternative here would probably be to just run open
exhaust!
Other Rules
A lot of the time, you'll hear someone talking about how much hotter the exhaust system on a turbo car gets than a naturally aspirated car. Well, if you are catching my drift so far, you'll know that this is a bunch of BS. The temperature of exhaust gas is controlled by air/fuel mixture, spark, and cam timing. Not the turbo hanging off the exhaust manifold.
When designing an exhaust system, turbocharged engines follow the same rules as naturally aspirated engines. About the only difference is that the turbo engine will require quite a bit less silencing.
Another thing to keep in mind is that, even though it would be really super cool to get a 4 inch, mandrel bent exhaust system installed under your car, keep in mind that all of that beautiful art work won't do you a bit of good if the piping is so big that it gets punctured as you drag it over a speed bump! A good example of this is the 3 inch, cat back system sold by Thermal Research and Development for the Talon/Laser/Eclipse cars. The piping is too big to follow the stock routing exactly, and instead of going up over the rear suspension control arms, it hangs down below the mechanicals, right there in reach of large rocks! So when designing your Ultimate Exhaust System, do be careful
now, that's general info of exhaust systems in general.. and if you have any info added to the write up be my guess.
here's info on our exhaust system:
stock exhaust manifold sizing: n/a
exhaust manifold ports sizing: n/a
stock exhaust piping is 1.75"
stock exhaust catalytic converter size: 1.75"
stock muffler style/ sizing: steel baffled, chambered, 1.75"
Stock 4AFE exhaust manifold picture, Note: the o2 outlet sensor is on the downpipe instead of the manifold itself:
Aftermarket 7AFE exhaust header, note where the o2 sensor manifold is:
i'll do a side to side comparison of the two when i get the chance...
Inagawa is offline   Reply With Quote
The Following 2 Users Say Thank You to Inagawa For This Useful Post:
Createdtoburn (01-05-2012), RogueMoog (11-11-2011)
Old 11-09-2011, 12:57 AM   #2 (permalink)
Inagawa's Avatar
Muffler:
well my stock muffler wasn't really stock per say, but it was a oem replacement. it's about 20pounds, ulgy and oval shape with broken chambers inside, luckly it fell off the exhaust pipe the first week of ownership of the car because of bad welds...
1.75" inlet and 1.75"outlet
I have a N1 style muffler, straight thru baffle inlet is 2.25", outlet is 3.75", weights six pounds, SIX POUNDS!!!!! Its imo a great replacement, and not a autozone crap "but cheaper than it too, lol"
Old 11-09-2011, 10:26 AM   #3 (permalink)
ayang951's Avatar
Gameroom cash: $163050
View ayang951's Photo Gallery
wow thats a lot of reading i just did... great stuff though.. that covers alot for lots of people.. =D but really nice... keep this on the real you know... =D
"I live my life one corner at a time, for those few seconds or less, im free."
~Mr.Yang
http://www.toyotanation.com/forum/sh...=1#post3365798
ayang951 is offline   Reply With Quote
Old 11-09-2011, 04:01 PM   #4 (permalink)
new sr5 guy
sincity.rolla's Avatar
View sincity.rolla's Photo Gallery
i think this could become a sticky, a lot of good info!!! by the way the exhaust port on the head of a 4afe is 33mm. havent found the manifold size though, we can assume its +/- 1mm of that no? good luck on ur exhaust build. if u have the funds u should get a base line dyno and a dyno when done to see results.
another 89 sr-5.....
89 corolla sr5 5spd. rip
06-elantra, wifes car
88-mr2...rip
88-corolla gts...sold
sincity.rolla is offline   Reply With Quote
Old 11-10-2011, 01:34 AM   #5 (permalink)
Inagawa's Avatar
yeah funds are slim so i have to wait on the Dyno run, it's $65.00 for three pulls so when i get the chance i will get the car on the Dyno, sadly i can't get a base because technically my car isn't stock but i could get a hold of someone with a completely stock AE91 from somewhere so it's all good. added our air is thinner so baseline results will be in differences, our power is held back by the air lol...
and before i personally get started on the exhaust work, i need to get the suspension done, the struts are too screwed up to ride with any aftermarket exhaust system, i'm bouncing like a low-low right now and its too much of a risk. i wanna do this correct, so preparations is necessarily needed.
Old 11-10-2011, 01:41 PM   #6 (permalink)
new sr5 guy
65 bucks damn i wish...around here i've heard 85 for 2. i hear ya on the struts, dont wanna ride around like a bobble head. my sr5 ran like that cause of the ebay coil sleeves and blown struts. sadly its no longer with us.... it was stock too so i could have done a baseline. ....
88-mr2...rip
Old 11-16-2011, 11:39 PM   #7 (permalink)
Inagawa's Avatar
Minor Update:
so i got my header in..
2"Downpipe:
These weird lil bolts:
They go on like this:
And nuts:
and all together:
2.5" catalytic converter... now they sent me a OBDll cat, idk why but it isn't going to hurt me, i'm just going to plug the hole up. and i have to get reduces because i'm going to be running 2.25" not 2.5" exhaust
drew up how the exhaust is going to be made.. pardon the weak skill..
Old 11-17-2011, 02:11 PM   #8 (permalink)
ayang951's Avatar
nice... are you going to get the cat welded onto the headers? the guy that did my new cat just cut the header flange and welded it... i was angry... i told him, after the flange...
~Mr.Yang
Old 11-17-2011, 05:31 PM   #9 (permalink)
Inagawa's Avatar
eww no, reduces and new flanges are going to be slapped on, i want a clean correct job like it was a aftermarket perfomance exhaust straight on from the shelf. and gives me the option to change it all out if i wanted. a bolt on affair.
i would of punched that guy...
Old 11-17-2011, 05:41 PM   #10 (permalink)
ayang951's Avatar
i would of punched that guy...[/QUOTE]
i wanted to so much... he was playing the "i dont know english" card...
~Mr.Yang
Old 11-17-2011, 05:52 PM   #11 (permalink)
Inagawa's Avatar
i wanted to so much... he was playing the "i dont know english" card... [/QUOTE]
smdh.. No Comment
Old 11-17-2011, 06:29 PM   #12 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
An exhaust isnt going to offer much increase in performance, because your head is going to be limiting in the flow department...
Old 11-17-2011, 06:57 PM   #13 (permalink)
Inagawa's Avatar
that's a whole other project on its on plus here the air is thin so small ports actually benifit. but whatever gain recieved is good with me.
Old 01-05-2012, 04:52 PM   #14 (permalink)
1990 Corolla GTS 4A-GE
Createdtoburn's Avatar
View Createdtoburn's Photo Gallery
I'm surprised there isn't more posts on here, or that it's not a sticky. That was probably some of the best information I've read on exhaust. Really interesting shit. Thanks.
Createdtoburn is offline   Reply With Quote
Old 01-06-2012, 01:13 AM   #15 (permalink)
Inagawa's Avatar
Update:
