removing old oil pan and installing new oil pan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2011, 01:58 PM   #1 (permalink)
View dvbagnasco's Photo Gallery
Hey guys,
I am removing my old oil pan because i accidentally crossed the threads when I did my last oil change, which caused a leak. So I bought a new oil pan and gasket and would like to know what I need to torque the oil pan bolts down to?
Any help would be appreciated. Thank you.
P.S. It is a 1990 Toyota corolla with a 4A-FE engine, if that helps.
dvbagnasco is offline   Reply With Quote
Old 11-14-2011, 12:48 AM   #2 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
My FSM says 43 in-lb. Take note, IN-LB not FT-LB just in case. Most people don't have an in-lb torque wrench. 19 Bolts and 2 Nuts.
SuperRA is offline   Reply With Quote
Old 11-14-2011, 09:22 AM   #3 (permalink)
MrRolla's Avatar
View MrRolla's Photo Gallery
1 inch pound force = 0.0833333333 foot pounds
43 in pounds = 3.583333333 foot pounds
Seems to be a really low torque setting but that's what the Chilton's Guide say's 43 inch lbs (5Nm).
Plz correct me if wrong.
MrRolla is offline   Reply With Quote
Old 11-14-2011, 04:52 PM   #4 (permalink)
RogueMoog's Avatar
Gameroom cash: $314030
View RogueMoog's Photo Gallery
Yeah, definitely take it easy when tightening those oil pan bolts/nuts. I broke one bolt last time I was under the wagon, even though I was using a torque wrench (yes, going by in/lbs).
RogueMoog is online now   Reply With Quote
Old 11-15-2011, 09:29 PM   #5 (permalink)
Yea, it's that low. They are small bolts and low grade bolts at that. It's really just a back up to the FIP gasket sealer you're supposed to use. Ever try to take a pan off with that stuff? Well, I guess you will be soon. (well not you but the OP)
Old 11-16-2011, 03:37 PM   #6 (permalink)
Gameroom cash: $134355
I use copper permatex RTV.... I hand tighten the bolts.... start with the guide studs then work my way around opposite.... then go back through again to ensure they're all roughly even.
Old 11-16-2011, 07:26 PM   #7 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Yeah! Over tightening these bolts can olso deform the pan flange.
It is also best to tighten on a wide surface like this in a criss-cross patern to reduce the chance of warping it.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 11-17-2011, 12:04 AM   #8 (permalink)
AE92
43 In-lbs. Cool. I was looking all over the internet thinking the information was already posted. I probably wasted 6 hours looking until I decided to finally post a thread.
Thanks guys. I really appreciate it.
