1990 Prizm/Corolla "door ajar" light issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2011, 03:02 PM   #1 (permalink)
View dhar2112's Photo Gallery
Hello!
I have a base model 90 Prizm. The "door ajar" light stays on all of the time now. Had a mechanic buddy do some work on the car recently and said he checked all of the doors and back hatch. The kill switches seemed to be working fine. I know that sensor is grouped with the turn signal sensor, "key in ignition" sensor, etc. on the wiring plug above the driver's side kick panel fuse block. It has a purple/blue connector. I don't need the light to come on to tell me if the door is ajar, so I'd like to clip the wire. Anyone know what color wire it is?
If it's different in the actual Corolla versus the Prizm, please let me know and apologies for posting here.
Thanks much!
dhar2112 is offline   Reply With Quote
Old 11-21-2011, 06:38 PM   #2 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Instead of cutting wires, remove instrument cluster and remove bulb.
90 GP is offline   Reply With Quote
Old 11-21-2011, 11:49 PM   #3 (permalink)
86camota's Avatar
View 86camota's Photo Gallery
ummm..... doors not ajar, doors a door
1986 Toyota Camry- sold
1990 Toyota Corolla All-Trac Sedan- rolled over to 200,000 miles.
Honor-Courage-Commitment
HOORAH!!
86camota is offline   Reply With Quote
Old 11-23-2011, 04:35 PM   #4 (permalink)
teh pwnager
View Rabbitbunny's Photo Gallery
I have the 90 Prizm factory manuals and I'll check tonight for you. Expect a reply in the morning.
Rabbitbunny is offline   Reply With Quote
Old 11-23-2011, 06:55 PM   #5 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Most likely the driver's door switch gone bad. Disconnect it.
Pull the door post trim panel, and pull the connector from the switch.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 11-24-2011, 01:48 PM   #6 (permalink)
teh pwnager
Hmm, the book just says it's a w/b wire, but that's pretty uyseless in these cars. Half the wires are w/b.
Old 11-27-2011, 08:00 PM   #7 (permalink)
Donald's Avatar
Any alignment shop should be able to get it straight for you. If it needs tie rod ends or ball joints, they will probably get them from NAPA or Autozone.
