Tashiros GT, Thank you for the post that led me to find the problem. You were correct it says to verify that the timing readvances to 10-16 degrees BTDC after the normal lineup is restored on the car... so I took a closer look.
The Haynes manual I am using tells me to jumper the "E1 and the T" terminals.
Upon a closer look, there is no wire in the "T" terminal to jumper. There are only 3 wires in that connector, B+, E1, and O2 if I remember correctly. Is this a procedure error, is it supposed to be B+ that is jumpered to the E1?
Thanks!
