Engine knock, broken piston
1988 Corolla SR-5, almost 329K miles on the odometer. It runs, but has a loud engine knock.
I finally got the oil pan down, suspecting that it was a bad rod bearing, but was quite surprised to find all the connecting rods nice and tight.
Looking up underneath, I see that #1 piston is missing a large chunk of skirt.
A quick peek into the oil pan, and there it is, or should I say, there they are......The bits and pieces of the broken skirt.
I pulled the valve cover and was astonished at how clean it is in there. It is the cleanest engine I have ever looked into. That tells me that it had been recently rebuilt, so the failing piston is probably the result of workmanship, and not materials.
The question in my mind though is, what did they do to cause this?
Lucky for me, I have a set of 4A-FE pistons and rods in a box in my storage shed.
I need to pull the head and see what the cylinder bore looks like, then decide which direction to go from here.
The plan is to get this car/engine driveable, so I can use it while I change out the synchro rings in the 7A-FE gearbox, replace some leaking seals in the 7A engine, and decide if I will keep it, or sell it and get a sedan.
I will try to post some photos soon.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
