I have done the 7A-FE swap, and am about to do it again, (same engine into another car).
It is a straight drop in, but if you use the 7A ECU, then you will ne to do wiring mods.
I am told that you can run the 7A with the 4A-FE ECU and wiring, but you will need to use a distributor from a 4A-FE, or an early &A-FE from a Celica. But, with the 4A-FE ECU, you will loose the protection of the knock sensor.
The 7A produces the same horse power (115) as the big port 4A-GE, but delivers more torque (115 lb at 2500 as opposed to 105lb at 5500), starting at 2500RPM and holding that torqure steady up till just short of redline, about 5500RPM. The 4A-GE just starts pulling at 4500 RPM.
You will get the best performance from the 7A-FE if you use the matching gearbox. A 4A-FE gearbox can be used but you will run out of first gear very quickly as this engine does not rev vary high. The 7A gearbox has a taller first gear, but all the other ratios are the same as the 4A-FE.
The 4A-GE gearbox will be totally worthless with the 7A-FE, since it has a higher final drive ratio (4A-GE = 4.3:1 / 7A-FE = 3.7:1) and will cause the engine to turn 500 more RPM at 70 mph in 5th gear.
Swapping from a 4A-GE to 7A-FE in my '89 GTS, I felt that the car was much quicker with the 7A, launching much harder because of the fatter torque curve starting at a much lower RPM, and having the same top end performance. It does require that you short shift more than rev it high.
I used 4A-GE pistons in my 7A, with the intent of boosting the compression, which it did on a static compression test, but I am not sure how much it increased the compression ratio. I still hope to get it dynoed to see what I am actually getting for hp and tq.
Below, is a link to my swap. There isn't a lot of detail about the actual installation, because it is that simple and straight forward, a straight drop in. Any questions, just ask.
4A-GE pistons in a 7A-FE engine
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
