4a-fhe swap with 4a-ge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2012, 07:23 AM   #1 (permalink)
View JDM-SPRINTERCARIB's Photo Gallery
i was wondering ....
can i use a 4a-ge (black-top 20v) engine in a 4a-fhe 4WD engine car without doing mod n maintaining the gearbox n 4WD ??
meaning to say change the original 4a-fhe engine to a 4a-ge(blacktop 20v) or a 4a-gze with changing the transmission (automatic)??
JDM-SPRINTERCARIB is offline   Reply With Quote
Old 01-15-2012, 09:31 AM   #2 (permalink)
RogueMoog's Avatar
Gameroom cash: $313930
View RogueMoog's Photo Gallery
Lightbulb
Welcome... Sounds like you have a Sprinter Carib / Corolla All-Trac (AE95)? Is it manual or automatic? People have put 4A-GEs / 4A-GZEs into these cars & wagons with success, despite some people (who don't read / research enough) saying the gearbox can't handle the stresses. If you go with a 20v, you just need to grind away a part of the block where there's a notch in the oil pan. The notch is for the transfer case which sits behind the engine. (Your 4A-FHE already has this notch in the block and oil pan -- keep that oil pan since you have the oil cooler lines and the notch for the transfer case.)
I believe the GZE blocks are all like a 16v block, which means they have to be ground down where there is no notch. This compromises the oil pan seal, so if you can live with an oil leak, then go ahead and use the GZE or 16v block. I'm doing a build using a late model 4A-FE block, so that I can use my All-Trac's oil pan. I'm sure you could use a 20v GE block with a 16v GE head, and not have that oil leak. 20v blocks do have oil squirters as you can see below. Of course you should change out the wiring harness and ECU for GE (or GZE) ones...
Here are some pics of blocks showing the oil pan side, all oriented the same way (oil pump on the right side). Last pic shows a 20v block in the process of being ground down for an All-Trac's transfer case. I posted these in another topic here, but it's worth showing again:
Early 4A-FE block:
16v 4A-GE block:
20v 4A-GE block:
20v 4A-GE block, being prepped for an AE95:
RogueMoog is offline   Reply With Quote
Old 01-15-2012, 09:47 AM   #3 (permalink)
Rogue-
tq for the info ...so now if be starting to find a 4A-GZE engine then .... :-)
and btw yes im using a sprinter carib ae95g (import from japan since its the cheapest 4WD n most unique car i've seen here in my region (southeast asia ) and its a 4A engine) tq again for the complete info :-)
Old 01-15-2012, 12:37 PM   #4 (permalink)
RogueMoog's Avatar
No problem! Stupid me didn't pay attention to your screen name well enough to see "Carib Sprinter" in it. What can I say, I had just woken up...
One more bit of info I forgot to mention. The crank MAIN journals are all the same for the 4A engines... it's the rod journals that are different. That being the big & small round ends of the rods -- for the 4A-GEs, 40mm x 18mm (such as early 16v bluetop and some black/red top), or 42mm x 20mm (such as later 16v black/red top, redtop, 20v silvertop, blacktop). I don't know about the rods for GZE since a super- or turbocharged build never really interested me.
There is however a manufacturer called Orion Engineering that makes 40mm x 20mm rods, so that you can use high compression (like 16v redtop) pistons with an older 40mm rod journal crank.
Old 01-16-2012, 09:54 AM   #5 (permalink)
he3 ..... ok dude thanks alot for the information there now im on mu way to see my mechanic n im definitely gonna show ur comment and hope he'll get the idea .... since he said it wont work ahahaha ..... its all sense the wat u r saying and tq again
