anyone know a 12v spot when car is running - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2012, 06:11 PM   #1 (permalink)
rdyzz's Avatar
Gameroom cash: $137500
View rdyzz's Photo Gallery
now im looking for 12volts only 13v is fine, but not 14v which most my cabin has for a voltage when the car is running. anyone know of a good spot for a 12-13v spot? or anyone know of a voltage regulator i can get?
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
rdyzz is offline   Reply With Quote
Old 01-16-2012, 09:36 PM   #2 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $316700
View SCT's Photo Gallery
If you pull the panel under the steering column off and you can see the wires, the solid yellow is the ignition wire which is powered when the key is in ACC or ON. It's the wire I used when I wired up an alarm. Goes off when the ign is turned.
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
SCT is offline   Reply With Quote
Old 01-17-2012, 12:29 AM   #3 (permalink)
Gameroom cash: $347685
View SuperRA's Photo Gallery
Unless something is especially regulated down to 12v, all you're gonna get on a properly charging car is 14+ volts. I'm sure there's a 12V voltage regulator you can find at an electronics store. How much current do you need?
SuperRA is offline   Reply With Quote
Old 01-17-2012, 07:08 PM   #4 (permalink)
rdyzz's Avatar
you know im not really sure what it is, all i know is for the msd 8920 tach adapter im using, its acting funny and being picky on voltage or current. im not very knowledgeable in electronics, but i tested my beams setup and its a 15.1v cold. inside car is 14.8 cold. when warmed up the alternator drops to a 14.8v and inside drops to 14.6v.
when i have the radiator fan working, blower motor running at full, and at one point had my reverse lights hooked up/on (gonna need to find a switched 12v for this, since the guy i bought the car from tapped into it or did somthing with its source for the alarm). the + wire i was getting power from was at 13.8v and the tach was working. as soon as i unplug 1 or the 3 things drawing power bringing it back to 14v+ the tach dies, lol if i roll up my windows with 2/3 things mentioned hooked up tach comes on and works till i stop using switch. this is why its leading me to believe that the msd box is picky about voltage, but talking to the techs at msd they claim the tach adapter can handle 18v....
its bothering me, i've ordered a new alternator since im thinking the voltage regulator is bad. all i've tested so far is volts nothing else. BTW how do i tell how much current there is? would that be amprage?
Old 01-17-2012, 09:50 PM   #5 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434050
View eage8's Photo Gallery
it's only higher when it's cold because the engine is idling higher I imagine.
amperage (current) is simply determined by how much whatever is plugged in pulls. that's why you have fuses to make sure it doesn't go above what it should be at.
sounds like a voltage issue to me... that is really high voltage, I think getting a new alternator to try out is a good idea.
'81 BMW R65
