Originally Posted by eberbs1
weak water pump maybe?
i recently worked on a mazda where the fins on the WP had literally corroded off. so this is definately a possibility.
altho, this car was also overheating badly.
Originally Posted by SuperRA
Maybe the control cable for the temp lever (heater controls) needs adjustment or has broken? It controls a door which switches between the hot air and cool air. It may be that the door is stuck midway or something.
i would check for this.
make sure the blend door is working correctly.
you may need someone to help, unless you can lay under the dash, AND work the controls.
you need to switch from hot to cold, while watching underneath. verify the cable is still attached, and that the lever for the blend door is making its full travel.
