Originally Posted by cEtnA
only motor. trans you'll need to mod. axles won't fit you'll need jdm hubs with axles i think. motor might not clear hood cuz of intercooler. and you should take all the plugs/connector from the mr2 igniter. you'll need ae92 its ps lines i think too
Sent from my SGH-T959 using AutoGuide App
You are correct about modding the gearbox, but I think you are wrong about the axle shafts. They will fit.
The intercooler will require some engineering. Either you run piping for a front mount intercooler, or cut an opening in the hood and add a hood scoop.
I think the MR-2 intercooler will clear the hood, but you will need to at least have louvers in the hood for air flow. I have seen a photo of one where the battery was moved to the trunk, louvers were cun in the hood, and a fan was mounted below the intercooler to suck air through it.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
