Just figured I would post this up since I haven't seen it anywhere else. This started because my flex section was breaking apart on my 4afe, and a replacement flex would have ran me 30 bucks plus it would have to be installed. A replacement press-bent front pipe would run 80 bucks. A 7afe header from ebay was all of 60 bucks shipped, so this seemed like the best option. Onto the pics.
First of all this header mimicks the factory header pretty close, but winds up being a tad shorter on the front pipe.
As you can clearly see the front pipe is shorter and the flange is at an incorrect angle.
There is quite a big difference in collector area, and being a 4-2-1 design it will have different resonance effects as well.
Once installed you will find that it sits like this, rendering it a non-"bolt-on" affair.
Nothing a quick modification can't solve.
And installed....
Overall it certainly made more power across the board from the swap, and the header is virtually silent, so no concerns about buzzy exhaust sounds. I found my economy increased around 2-2.5mpg highway, and all around the power seemed to pick up a bit. Overall I'm satisfied with the results, and feel it was far better to do this than run another press-bent front pipe. You could easily gut the cat at the same time since we are dealing with a car that has no rear O2 sensor, for even more gains.
Some notes:
-This is an ebay header, you need to automatically assume that the flanges are warped. Take them to a belt sander and ensure that they are flat.
-The head flange bolt holes did not line up very well and had to be wallowed out a bit on the outsides. I am not sure if every header will be like this, as I'm sure the quality controls in China don't match OEM standards
. This is nothing that a simple drill bit or dremel can't solve. Just be sure to file the surfaces smooth afterwards so that the exhaust stud nuts have a clean engagement surface.
-The hanger mount does not match the factory setup. I removed the OEM hanger mount completely and have the header hanging in open air, supported solely by the head and the other exhaust hangers. You can bend the other hangers down a bit to lift the exhaust up if you have subframe clearance issues.
