91 corolla cranks longer to start over when it sits for a day or 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 6th Generation (1988-1992) Specific discussion of the AE92
 1Likes
  • 1 Post By Rookie_One
post #1 of 8 Old 03-19-2017, 09:03 PM Thread Starter
Senior TN Member
Quoted: 234 Post(s)
(Thread Starter)
Hello i have a 91 corolla and if i let it sit for a day or 2 the car cranks longer then starts up with a sputter or like a miss. Anyone have this issue? It just started doing this.
Sent from my LGMS631 using Tapatalk
kobej05 is offline
post #2 of 8 Old 03-19-2017, 09:09 PM
sdspeed's Avatar
Quoted: 163 Post(s)
It's jealous of your T100
sdspeed is online now
post #3 of 8 Old 03-19-2017, 09:14 PM Thread Starter
Senior TN Member
Quoted: 234 Post(s)
(Thread Starter)
Right lol. Truck never let me down in the 3 yrs i owned it. Had 268k on it just hit 329k.
kobej05 is offline
post #4 of 8 Old 03-20-2017, 06:33 PM
Corolla Lover
Rookie_One's Avatar
Quoted: 3 Post(s)
Might be normal, since the pressure in the fuel line probably dropped during that time.
Just leave the key at On without starting the engine for about 30 seconds - 1 minutes, giving the time for the pump to build up the pressure again
kobej05 likes this.
Rookie_One is offline
post #5 of 8 Old 03-20-2017, 10:39 PM
Senior TN Member
Prizdog's Avatar
Quoted: 171 Post(s)
It's almost always the cold start injector when these cars have trouble cold starting. It would probably benefit from being taken apart and cleaned. Maybe even start by simply dumping seafoam in the gas tank next time you fill up.
1991 Toyota Corolla- 4A-FE, C52 - 250,000+ miles
1990 Toyota Corolla- 4A-FE, A131L - 214,000 miles
1991 Geo Prizm- 4A-FE, A131L - 257,000 miles
Prizdog is offline
post #6 of 8 Old 03-20-2017, 10:43 PM Thread Starter
Senior TN Member
Quoted: 234 Post(s)
(Thread Starter)
I will try that thanks
Thanks will do i most of the time use shell reg gas and v power. The last oil change which is almost due i had the injector clean treatment. They used this one tool and they hooked it to the booster hose its some strong treatment i had to replace my plugs after.
kobej05 is offline
post #7 of 8 Old Yesterday, 12:49 AM
Senior TN Member
Quoted: 982 Post(s)
Except that the ECU doesn't run the fuel-pump unless the engine's spinning. Either starting or actually running.
DannoXYZ is offline
post #8 of 8 Old Today, 01:04 AM
Senior TN Member
Quoted: 19 Post(s)
I could be wrong, but it probably primes for a few seconds after turning the key on like most other cars, but yea nothing close to 30 seconds or 1 minute!
SuperRA is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 6th Generation (1988-1992)
User Tag List
Linear Mode Linear Mode
« Back
