Corolla 1991 Air/con Blower Not Working - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 6th Generation (1988-1992) Specific discussion of the AE92
post #1 of 12 Old 12-09-2009, 02:39 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
hey people i have a 1991 corolla 1.6 4a-ge engine and my aircon is not working simply when i got in side and turn it on nothing happens there isnt anything blowing the a/c button and everything is on i check all fuses and working 100% does anybody know and relays etc that can cause the blower i presume to stop working.
thanxx all help appreicated!
wrxstippp is offline
post #2 of 12 Old 12-09-2009, 03:57 AM
Senior TN Member
Quoted: 0 Post(s)
If the blower doesn't work check the fan circuit breaker in fuse panel behind kick panel on passenger side . The circuit breaker is resettable. On the top is a small hole. Use a small nail/ paper clip and insert into hole and press inward to reset breaker. Also check the blower resistor which mounts in the blower housing.
90 GP is offline
post #3 of 12 Old 12-09-2009, 04:03 AM
Senior TN Member
Quoted: 0 Post(s)
Here is a link to a wiring diagram that you can use with a voltmeter to trace your wiring to troubleshoot blower not working. The heater/a/c diagram for a 4AFE engine is Figure 6.
http://opc.mr2oc.com/online_parts_ca...CorollaFWD.pdf
90 GP is offline
post #4 of 12 Old 12-09-2009, 04:32 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
thanx people
The Circuit Breaker Is getting Power So should i still reset it or could it be another problem thanx for any help is appreciated!
post #5 of 12 Old 12-09-2009, 12:18 PM
Senior TN Member
Donald's Avatar
Quoted: 6 Post(s)
The resistor block, inside the blower duct is the thing that generally dies first.
When that dies, it will usually only affect one position on the fan switch, but it can sometimes just kill the whole thing.
That will probably the cheapest thing to change, and the easiest to check.
Where exactly it is located I don't remember, but I think it should be somewhere downstream of the blower motor. You should see wires going to a block in the duct from the blower motor.
Somewhere behind the glove box.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension, brakes, interior.
'87 Corolla, AE82 FX-16, 4A-GZE swap (auto-X'er)
'01 Tundra SR-5, 4WD, V8.
Donald is offline
post #6 of 12 Old 12-09-2009, 03:04 PM
Senior TN Member
Quoted: 0 Post(s)
I would attempt to reset breaker just to rule it out. To find the resistor block look for the plug in harness on front side of blower housing.
90 GP is offline
post #7 of 12 Old 12-09-2009, 08:43 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
i reset the breaker and it worked
but then it stoped working after 1 hour so im gusing the breaker needs replacing
thanx for yur help ppl
post #8 of 12 Old 12-09-2009, 09:30 PM
Bitter's Avatar
Quoted: 1614 Post(s)
i would guess that the blower motor itself may be bad and drawing too much power once it gets hot, popping the breaker.
Bitter is online now
post #9 of 12 Old 12-10-2009, 03:08 AM
Senior TN Member
Quoted: 0 Post(s)
If you reset it and it tripped I would then check the blower resistor. On mine there was corrosion on the terminals inside it and it caused the breaker to trip. Also you usually get a slight burning smell which is the resistor getting too hot .
90 GP is offline
post #10 of 12 Old 12-10-2009, 12:25 PM
Senior TN Member
Donald's Avatar
Quoted: 6 Post(s)
It could possibly be a bad breaker, but I would say check the motor and resistor first.
Donald is offline
post #11 of 12 Old 12-14-2009, 05:37 PM
Senior TN Member
retiredat44's Avatar
Quoted: 48 Post(s)
Exclamation
do not ever try to outsmart a good working breaker, if it is working correctly, it is stopping the electrical system from disaster!
2014 Camry Hybrid XLE
retiredat44 is offline
post #12 of 12 Old 12-16-2009, 05:23 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
installed yuu breaker and new blower and is working 100% so far!
hopefully problem fixed thanx 4 all advices!
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 6th Generation (1988-1992)
User Tag List
Linear Mode Linear Mode
Back
