Rattling noise when driving over bumps, etc - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 6th Generation (1988-1992) Specific discussion of the AE92
post #1 of 9 Old 03-06-2010, 10:09 PM Thread Starter
91 Corolla DX
freakgasolinefight's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Hey, guys. I haven't been on this forum in a while, but I could really use a little help if anyone has a moment.
I have a '91 Corolla DX with about 68,000 miles on it. For a while now, it's been making knocking/rattling noises when going over bumps. I thought it was probably the CV joints (they were truly jacked) and I had them replaced, but the car still rattles quite a bit on bumpy terrain or while going over a speed bump, etc. I thought maybe a broken strut or spring, but I'd think one of the two different mechanics that've looked at my car in the past two months (one changing front tires, the other replacing the front axles) would have noticed that. I looked at them myself, and they look fine. The car does not noticeably sway or bounce, though if I cut a hard corner coming down a hill there's be a big clunk like the suspension has just bottomed out.
Any thoughts? I'd love for this to be something I could fix myself.
"When a true genius appears in this world, you may know him by this sign; that the dunces are all in confederacy against him."--Jonathan Swift
freakgasolinefight is offline
post #2 of 9 Old 03-07-2010, 12:23 AM
SCT
iAzn
SCT's Avatar
Quoted: 0 Post(s)
Check the lower ball joints.
And check the exhaust system. It can be a loose part, low hanging, etc. and can be the source of some sounds when going over bumps.
1988 TOYOTA COROLLA SEDAN
4AGE 20V In Progress
1995 LEXUS SC300
Just Got It!
SCT is offline
post #3 of 9 Old 03-07-2010, 05:30 AM
Senior TN Member
Quoted: 0 Post(s)
Jack up the car to get the weight off the tires and grasp a tire and check for up/down and side to side play.If you have a front sway bar that could have broken parts as well. If it makes that much noise when driving it should be easy to spot the problem.
90 GP is offline
post #4 of 9 Old 03-07-2010, 02:22 PM Thread Starter
91 Corolla DX
Quoted: 0 Post(s)
(Thread Starter)
I don't think it's exhaust. It seems to be coming very distinctly from the front end of the car. I'm definitely going to jack it up later today or tomorrow and poke around to see what I can find.
post #5 of 9 Old 10-14-2010, 06:52 AM
Quoted: 0 Post(s)
So.... what was it?
pickedaname is offline
post #6 of 9 Old 10-14-2010, 10:00 AM
Rotary guy...
eage8's Avatar
Quoted: 2 Post(s)
I would say it's probably the strut top mount...
'81 BMW R65
eage8 is offline
post #7 of 9 Old 10-14-2010, 06:04 PM
ELUSIV Rolla's Avatar
Quoted: 0 Post(s)
Or a popped shock, but that's more of a clunk than a rattle. My car felt like it was on bump stops when the back one bit the dust. Check engine mounts too. When my rear one went to God it had a rattle. My 2 cents.
(ELUSIV)
ELUSIV Rolla is offline
post #8 of 9 Old 10-16-2010, 09:48 AM
Mr. Nice Guy
canadianae92's Avatar
Quoted: 0 Post(s)
yep shocks that are done for will make a clunk clunk over bumps sometimes, push down on each corner, the corner shouldn't oscillate
possible it could be ball joints mounts or sway bar links too
canadianae92 is offline
post #9 of 9 Old 10-16-2010, 11:20 AM
Senior TN Member
Quoted: 0 Post(s)
I agree with the upper strut mount. They can cause quite a racket when they are toast.
90 GP is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 6th Generation (1988-1992)
User Tag List
Linear Mode Linear Mode
Back
