20V Blacktop Hesitation - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 6th Generation (1988-1992) Specific discussion of the AE92
post #1 of 44 Old 05-24-2010, 05:40 PM Thread Starter
Senior TN Member
Donald's Avatar
Quoted: 6 Post(s)
(Thread Starter)
I started this thread because I still had questions about the Blacktop hesitation, and we had alrady clutterd up the one about the C-52 gearbox with hesitation chatter.
C52 + 20v
I also thought it might help anyone doing a search later.
Anyway, for all those who have experienced the hesitation of a 20v Blacktop the question I have now is, were these cars running the stock airbox, anykind of airbox, an after market cone filter, or open trumpets?
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension, brakes, interior.
'87 Corolla, AE82 FX-16, 4A-GZE swap (auto-X'er)
'01 Tundra SR-5, 4WD, V8.
Donald is offline
post #2 of 44 Old 05-24-2010, 06:18 PM
BackYard Engineering
Evo_lucian's Avatar
Quoted: 0 Post(s)
My brother's car gets this hesitation, air box is still stock with generic autostore drop in filter inside. The car is entirely stock ae111 levin. The problem usually happens when the car isnt warmed up, around 3000rpm. I will try to get a vid sometime this week.
The only thing in life worse than being talked about is not being talked about
My website updated 6/May/11
http://budgetracer.webs.com/
Evo_lucian is offline
post #3 of 44 Old 05-24-2010, 10:29 PM
Senior TN Member
rdyzz's Avatar
Quoted: 26 Post(s)
i ran with the t3 velocity stacks with itg filters. i tried everything. the funny thing was the engine ran best when the o2 sensor was unplugged. got a new 6 speed ecu and o2 sensor and it still did it on very slightly.
"driving safe doesn't mean driving slow"
90' corolla - world's first 2gr v6 swapped ae92
rdyzz is offline
post #4 of 44 Old 05-25-2010, 06:22 PM Thread Starter
Senior TN Member
Donald's Avatar
Quoted: 6 Post(s)
(Thread Starter)
That's not very encouraging to hear.
I was thinking maybe it was running without the airbox or the plenum that was the problem.
Now that's confusing.
Donald is offline
post #5 of 44 Old 05-26-2010, 04:25 PM
Evo_lucian's Avatar
Quoted: 0 Post(s)
If it makes any difference, the car has a broken o2 sensor. Don't know if that's the cause
post #6 of 44 Old 05-26-2010, 04:56 PM Thread Starter
Senior TN Member
Donald's Avatar
Quoted: 6 Post(s)
(Thread Starter)
After reading what rdyzz posted, I am not so sure.
Donald is offline
post #7 of 44 Old 05-26-2010, 06:14 PM
Resident asshole
Flashmn's Avatar
Quoted: 2 Post(s)
if the engine had aftermarket header then placement of the O2 sensor can cause issues with it... taking it off means the engine is running without closed loop correction, thus it alters the fueling slightly.
Flashmn is offline
post #8 of 44 Old 05-26-2010, 06:47 PM
Evo_lucian's Avatar
Quoted: 0 Post(s)
That sounds logical but i know of other owner of stock blacktops with stock headers and o2 sensor in tact that still get the hesitation. Rdyzz said he still had the hesitation with the o2 sensor so i really don't know. I have an o2 sensor to install on the car so after that i will see if the issue persists.
post #9 of 44 Old 05-26-2010, 08:33 PM
Quoted: 1 Post(s)
if anyone read that thread I posted about the green ae101 we blacktop swapped, his car is running stock itb box with generic cone filter, stock header and downpipe with gutted cat. all vacuum lines hooked up correctly and iscv working. He has put on about 5000km since we swapped it and only gets a slight hesitation when its cold in lower rpm's. And I think the best he got on 40L of gas has been almost 500km's.
WTB: Rear TRD sway bar for ae92
4doorGTS is offline
post #10 of 44 Old 05-27-2010, 04:59 AM
Quoted: 0 Post(s)
AE92
just putting it out there my 4AF does this aswell when it's not warm but when it's hot it runs fine im running aftermarket headers and airfilter it has done it without all the aftermarket parts aswell
NZAE92 is offline
post #11 of 44 Old 05-28-2010, 01:53 AM
Quoted: 0 Post(s)
Is this common on blacktops? Or is it a hit or miss?
Someone on the 4ag forum believed its in the factory tune. And I found a thread on a different forum a while ago where they used a honda ecu and rigged up a honda dizzy and tuned it like that. Said its unbelievable how much better the car runs. just my two cents.
Edit:
Found it. May try on 4afe for boost.
http://forums.club4ag.com/zerothread...&postid=681332
kwint is offline
post #12 of 44 Old 05-28-2010, 03:03 PM Thread Starter
Senior TN Member
Donald's Avatar
Quoted: 6 Post(s)
(Thread Starter)
Might be timing off, or throttle position sensor.
Edit:
This is very interesting, and if we could get more details it would be great. Does anybody know how to falsh a honda ecu?
Donald is offline
post #13 of 44 Old 05-28-2010, 04:29 PM
Rotary guy...
eage8's Avatar
Quoted: 3 Post(s)
it seems to me running a megasquirt (DIYPNP) is way easier... but I may be a bit bias
'81 BMW R65
eage8 is offline
post #14 of 44 Old 05-28-2010, 08:13 PM Thread Starter
Senior TN Member
Donald's Avatar
Quoted: 6 Post(s)
(Thread Starter)
I strongly believe you are right!!
Donald is offline
post #15 of 44 Old 05-28-2010, 08:42 PM
Evo_lucian's Avatar
Quoted: 0 Post(s)
Chipping kit only $19.50
http://www.xenocron.com/chipping-kit...cus-p-277.html
How to chip the ecu
Base maps are readily available online for free. This seems to be a much easier and cheaper option than megaquirt. Go to junk yard, pull ecu,harness, and sensors from honda. Wire it up tp 4ag, probably might be less work than wiring up a megasquirt if you don't get the pnp. Chip ecu, download a basemap and tune away. If a friend didn't offer me a free emanage blue i might have attempted to do this on my 4agte
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 6th Generation (1988-1992)
User Tag List
Linear Mode Linear Mode
Back
