rear disc brake conversion - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 6th Generation (1988-1992) Specific discussion of the AE92
post #1 of 14 Old 01-28-2012, 08:56 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
So, I'm really interested in converting my cars drum brakes to disc and I was wondering what is even possible to replace it with, in terms of usability and availability of parts and things like that. I'm not looking to make my car into a high performance machine, just looking to make some basic upgrades to my car and make it an awesome daily driver to last me even more then it already had. I was reading that I would have to get it all off the GTS model through searching, but I was wondering if that's the only one. And if so, I would basically have to replace the whole assembly and lines and master cylinder and everything?
bigsexypanda is offline
post #2 of 14 Old 01-29-2012, 12:34 AM
Quoted: 1 Post(s)
i did this on my sr5 with new
calipers,disk,pads,brakecable, and lines.
list.
gts brake lines
both rear caliper,pad,disk. just buy a new caliper or rebuilt it if you want, new pads and disk aswell
rear hubs / uprights
trailing arm or you can grind it to fit
both handbrake cable
you dont need the MCylinder your sr5 one is fine
exhuast pipe is on the way and heatshild to get to the handcables
goodluckdude
808diemar is offline
post #3 of 14 Old 01-29-2012, 07:59 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
did you mean exhaust pipe is IN the way?
Thanks and is the GTS system the best way to go or only way to go?
post #4 of 14 Old 01-30-2012, 02:54 AM
Quoted: 1 Post(s)
If somebody hve sold me a gts before i did all the
suspension,swaybars and reardisk ....l would've just get the GTS....
only thing im not touching is the engine......
post #5 of 14 Old 01-30-2012, 03:11 PM
Banned
Quoted: 0 Post(s)
The exhaust and heatshield is in the way for swapping the handbrake calbes.
The rear discs from an GTS may not be the best way and certainly not the only way but it sure is the easiest way.
I myself are in the proces of fitting the ST205 rear (and also front) brakes abut in my case this requires swapping to 5 lug hubs as well. Overkill? Yeah probably.
Check out this topic for some more info: http://web.archive.org/web/200806032...s.com/main.htm
SX/GTi/GTS/GTZ/GT all have the same rear disc setup so don't worry about that.
MzKzM is offline
post #6 of 14 Old 01-31-2012, 03:25 AM
Quoted: 1 Post(s)
ohh and before i put the agx insert on the gts strut casing, i try'd it on
the st184 front strut casing and it fiitted. i save the casing and cut the
brackets from the old sr5 rears and weld it on the st184 casing if i have
time but one day i was looking for it and found out my granma throw it away
post #7 of 14 Old 01-31-2012, 09:57 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I was wondering what places you would recommend looking for these kinds of parts.
post #8 of 14 Old 02-01-2012, 06:15 AM
Banned
Quoted: 0 Post(s)
I honestly don't know as I don't live in the USA. I got myself a corolla GTi and swapped the rear brakes & engine and then sold it again as an XLi. But you could try the junkyard / ebay / yahoo! or something similar.
MzKzM is offline
post #9 of 14 Old 02-01-2012, 04:53 PM
Senior TN Member
Donald's Avatar
Quoted: 6 Post(s)
In my opinion, you stand to gain more improvement with a larger front disk, than from a rear disk swap, and it will be a bit easier. You can get larger front brakes from the '90-91 GT-S or the '93-98 sedans.
Check out the two links below for front brake upgrades:
http://www.toyotanation.com/forum/13...e-upgrade.html
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension, brakes, interior.
'87 Corolla, AE82 FX-16, 4A-GZE swap (auto-X'er)
'01 Tundra SR-5, 4WD, V8.
Donald is offline
post #10 of 14 Old 02-01-2012, 10:10 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
^ Thanks man, I was about ready to just start going through the pages of posts to start finding people that have done it before.
post #11 of 14 Old 02-01-2012, 11:57 PM
Rotary guy...
eage8's Avatar
Quoted: 2 Post(s)
more brake info than you ever wanted:
http://www.toymods.org.au/forums/faq...ade-guide.html
'81 BMW R65
eage8 is offline
post #12 of 14 Old 02-02-2012, 05:05 PM
Senior TN Member
Donald's Avatar
Quoted: 6 Post(s)
You do know that there ios a search feature on the front page, right?
That is why it is important that we "Title" our threads clearly with the subject of the post, so searchers can know what the content is.
Donald is offline
post #13 of 14 Old 02-03-2012, 04:02 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Trust me, I've been on enough forums to hear enough people say use the search function. Well, just like you were saying a lot of times the titles not right and I've searched plenty.
post #14 of 14 Old 02-07-2012, 01:14 PM
Living on a Rock
kaitaiya's Avatar
Quoted: 1 Post(s)
you live in cali. start with a local pick your part. you can take the whole rear assembly from a GTS if you can find it. the crossmember unbolts with i think 6 or 8 bolts from the bottom of the body. and then it's the sway bar, the strut mounts and the hoses and brake lines. the arms will bolt in. if you take it with the arms and all it'll make it easier.
解体屋 Just a gearhead in paradise...
93 JDM AE102 20V Blacktop Blacktop Wiring DIY
The Somewhat tips and trick to the install
Proper Planning and Preparation Prevents P*** Poor Performance.
kaitaiya is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 6th Generation (1988-1992)
User Tag List
Linear Mode Linear Mode
Back
