how to tension alternator belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 6th Generation (1988-1992) Specific discussion of the AE92
post #1 of 5 Old 11-12-2012, 01:28 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
i know it sounds like a remedial question but, how do you tension the belt? i have a '90 sr5 with a 4afe. all i see is the slider/adjuster bracket thing above the alternator whereas a friends one there is no slider/adjuster bracket. its just bolted straight to the block. i heard im supposed to have 2 bolts. a pivot bolt and the adjuster bolt. but i only see one bolt? i want to put a little more tension on the belt because i can turn the belt a little past 90 degrees. (i dont have a belt tension gauge). however ive put the alternator to its furthest most point as i can on the adjuster bracket. so what gives. i want to know if im doing correctly.
lovely10 is offline
post #2 of 5 Old 11-12-2012, 05:12 AM
Senior TN Member
Quoted: 0 Post(s)
To check tension you press the belt inward at midpoint of length. It should deflect inward approx. 1/2 inch when pressed. You don't check tension by twisting it. On mine to adjust I believe you loosen both upper and lower mount bolts and adjust tensioner and then tighten mounting bolts. If you over tighten tension you risk the bearing failing in the alternator. If you are at the end of adjuster travel already it is either severely overtightened or worn out.
90 GP is offline
post #3 of 5 Old 11-12-2012, 01:32 PM
Senior TN Member
retiredat44's Avatar
Quoted: 48 Post(s)
Lightbulb
Our belts constantly squeak, but I will not tighten them any more, I don't want to ruin any bearings on the water pump, alternator, power steering or a/c. I spray a little stop squeak on the blets, but they start squeaking again in a couple days... my wife says the noise really bothers her,, but there is not much I can do, short of replacing these belts, but they seem to be in good condtion, I replaced a couple over the years..
I would rather be inconveinced with squeak then ruin bearings..
2014 Camry Hybrid XLE
retiredat44 is offline
post #4 of 5 Old 11-18-2012, 03:04 PM
RockstarLeo's Avatar
Quoted: 0 Post(s)
If you are maxed on the adjuster and your belt is still loose its time to replace it. Also if it squeals. It'll cost you 10 dollars for a belt. There are supposed to be 2 bolts. But if you only have one then maybe you should find the hole where the other bolt goes into the alternator and into the engine and install a new bolt. That way you have a pivot point to make use of your adjuster bracket.
1992 LSX Corolla 4AFE just passed 160,000km mileage
Evangelion "You Can (Not) Advance"
RockstarLeo is offline
post #5 of 5 Old 11-18-2012, 04:28 PM
Senior TN Member
Quoted: 48 Post(s)
Lightbulb
mechanics have, or should have, a built tension gauge... but most people don't buy all that stuff and just use the press with finger or screwdriver test..
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 6th Generation (1988-1992)
User Tag List
Linear Mode Linear Mode
Back
