Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 86 1 Ton - Axle Replacement
View Single Post
Old 07-20-2006, 08:00 AM   #2 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Re: 86 1 Ton - Axle Replacement
My instinct is that the 1-ton axle will be much bigger (stouter) than the
standard axle. The weight capacity of a vehicle is determined by the axles.
Well, there is some other stuff too, but there is no point in using most of
the other stuff if light duty axles are used.
"Kevin" <kreynolds@aviagen.com> wrote in message
news:1153359225.170913.254590@m73g2000cwd.googlegroups.com...[color=blue]
> Hey There,
> Can someone give me a pointer? I spun out and bent an axle awhile back
> (still drivable though). I picked up an axle from an 86 pickup at a
> salvage place, but the backing plate doesn't match. I think it came
> out of some other 86 model (it was picked clean so hard to tell what
> exactly it was, and I didn't get the VIN).
> Does anyone know if the axles are interchangeable on all the '86
> pickups? If so, then I'll just get a machine shop to press out the old
> axle and put in the new with a new bearing on the backing plate
> currently on the pickup.
> Thanks in advance,
> Kevin
>[/color]
