Re: 96 RAV4 Ignition Coil Testing
My problem was the timming belt.
Jeff Strickland wrote:[color=blue]
> "shavros" <marius_bingue@yahoo.com> wrote in message
> news:1153058515.461058.120110@b28g2000cwb.googlegroups.com...[color=green]
> > Mike wrote:[color=darkred]
> >> news:1153034328.078189.276120@m79g2000cwm.googlegroups.com...
> >> > I'm getting a 00.5 ohm reading on the primary coil. Ohmmeter is set on
> >> > 200 ohm. The specs are Cold: 0.36 - 0.55 Ohm Hot: 0.45 - 0.65 Ohm. Do
> >> > i need to replace coil?
> >> Not according to what you posted. That reading is within spec.[/color]
> > Thank You
> >[/color]
> Re read your first post. I think you made an error in the placement of the
> decimal point, the error affects whether or not the coil is within spec.[/color]
