Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Suspension
Thread: Suspension
View Single Post
Old 07-23-2006, 02:09 AM   #2 (permalink)
freakinbox
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
macpherson strut should only need the 3 nuts on the top, 2 bolts at the bottom disconnect the brake line from the strut and remove. as for taking the spring out. DO NOT do it without a spring compressor as it's under load so removing that nut at the top will probably end up with you hurt. If you don't want to mess with it a shop can do it for you. Then put back in the way you got them out
it comes out as an assembly.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
