Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Won't crank over.....99V6
View Single Post
Old 07-25-2006, 12:19 AM   #12 (permalink)
v-cam
this is what i say >
v-cam's Avatar
View v-cam's Photo Gallery
^ Still a battery problem. A starter motor uses a huge amount of power to turn over, so your battery must be at very high levels to turn over properly.
Hook up your voltimeter to your current battery and then turn the car over. You will see that it holds 12.5 volts at normal, but as soon as you turn the key it will drop down to 3 or 4 volts. The same will probably happen to your bench battery.
Get a new battery and eliminate that first. More than likely your car will start.
True car enthusiasts are open-minded to everyone's creation
v-cam is offline   Reply With Quote
