Autogauge tachometer not showing right rpm - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Corolla Lounge
Corolla Lounge A place where Corolla owners can discuss non-automotive subjects
Old 03-28-2008, 03:52 PM   #1 (permalink)
View trueno_ae101's Photo Gallery
I installed an autogauge tachometer into my 1992 toyota trueno 4afe. I hooked up the power wire to the cigy lighter fuse and the white one to the gauges fuse. The tacho and backlight work but the guage is not showing the correct rpm. When i start the car it sits on about 200rpm when my factory one shows 1000rpm. i have hooked the green wire to numerous places including the blue wire on the dizzy and at the diagnostics box and also i took out my guage cluster and hooked it upto the wire with feeds into the guage cluster itself but still it does not show correct rpm. Any one have ANY ideas at all?? could it be not enough volts to the guage? I am very lost at this point. Help needed lol
Cheers
trueno_ae101 is offline   Reply With Quote
Old 03-28-2008, 08:00 PM   #2 (permalink)
View toyomoho's Photo Gallery
Remove the back cover and check for a switch(s) that adjusts the tack output to the number of engine cylinders.
If red, white, green and black wires; try red 12+, white dash lights, black ground, green negative ignition coil terminal.
Old 03-28-2008, 11:09 PM   #3 (permalink)
thanks for your reply mate but ive already done all of that. cheers neway
Old 07-07-2008, 05:13 PM   #4 (permalink)
Speedy1's Avatar
View Speedy1's Photo Gallery
hey, I had the exact same problem with my ae92. only the car nearly limited at 4000 RPM. still dont know what it is. . .
Speedy1 is offline   Reply With Quote
Old 08-04-2008, 04:43 PM   #5 (permalink)
View mandiees's Photo Gallery
I had the same problem with this brand in a non-Toyota, I never did figure out what the issue was.
mandiees is offline   Reply With Quote
