I have an ignition problem!! HELP!
I have had a problem w/ mu truck keeping a stable idle after I push in the clutch. the engine RPM's will drop and bobble around @ about 250 or lower and then the idle will stablize at about 750. I was told by a mechanic that I needed a new O2 sensor and that should solve the problem. I replaced the O2 sensor and I still have problems with the idle staying stable after I have been running. Also, recently, I have had to run the started pretty hard to get it to turn over. There seems to be a blue cloud when it finally kicks over. Any ideas on whats wrong are welcome.
