I have a similar problem with my '92 Toyota truck. When I depress the clutch the truck will die, idle rough and suddenly die. It often does the same when driving at low rpms. I was told it may be the throttle position sensor, it wasn't. When it dies I can re-start it just fine. When it does this the engine light comes on. If I rev it the light goes off until rpms drop. I've put some good commercial injector cleaner through it and cleaned the intake. Let me know if you come up with ideas and I will do likewise.
