Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Fix a Flat
Thread: Fix a Flat
View Single Post
Old 08-02-2006, 04:45 PM   #3 (permalink)
joe
Guest
Posts: n/a
View joe's Photo Gallery
Re: Fix a Flat
On Wed, 2 Aug 2006 15:46:14 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>"joe" <nonspam@invalid.com> wrote in message
>news:r512d2dasilochu1v4gd71hku25ddnf8vn@4ax.com...[color=green]
>> In the past I have used Fix A Flat or similar inflate from a can
>> products to fix 9 out of 10 flats - and who knows how many I never
>> knew about.
>> On the can it says "Do not use on tire sensor technology."
>> Is this just another Q-tip warning to be ignored or what gives? It
>> says it is non flammable -so what is the problem with simply leaving
>> the stuff in the tires forever.
>>[/color]
>Fix a Flat and green slime stuff basically work by coating the entire inside
>of the tire and wheel with stuff that eventually cures to the consistency of
>rubber. If that stuff coats the sensor, it would keep the sensor for
>detecting the true air pressure.
>[/color]
So I should not use it. What is that sensor? Is it fastened to the
rim inside the tire? What happens when one fixes the tire with either
a plug or patch on the inside?
I think I need the ability to fix flats more that the this sensor
technology. What would I be giving up?
j
