Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Fix a Flat
Thread: Fix a Flat
View Single Post
Old 08-02-2006, 09:16 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Fix a Flat
"joe" <nonspam@invalid.com> wrote in message
news:13k2d252e4cqd0corvjp92de95sn0aidip@4ax.com...
<snipped>
[color=blue][color=green]
>>Studies have shown that the majority of the vehicles on the road have
>>under-inflated tires, which increases the chances of a blowout. The TREAD
>>act will require all passenger cars to have a tire pressure monitoring
>>system so you are starting to see some early implementation.[/color]
> This must be part of a fuel saving program?[/color]
Probably a combination of fuel savings and safety. The Firestone Tire -
Ford Explorer rollover problem was attributed to low tire pressure.
[color=blue]
> It is my understanding that the sensor on my S will only detect
> differential pressure. So if all four tires are running at a sloppy
> 25 psi all is fine per the sensors. I should have 35-40 psi.[/color]
I believe that your understanding is correct, however, the likelihood that
all four tires will lose air at the same rate is pretty slim.
[color=blue]
> Is there any real difference between the different 'slime' or any of
> the fix a flat products? They probably have all become non
> flammable.
> j[/color]
I've never used any of those products so I do not know if there is any
difference in them. Slime is water based and supposedly sensor-safe. I've
seen tires broken down that had those products inside and they are pretty
messy.
Ray O
