Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Fix a Flat
Thread: Fix a Flat
View Single Post
Old 08-02-2006, 10:09 PM   #11 (permalink)
joe
Guest
Posts: n/a
View joe's Photo Gallery
Re: Fix a Flat
On Wed, 2 Aug 2006 21:16:19 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>"joe" <nonspam@invalid.com> wrote in message
>news:13k2d252e4cqd0corvjp92de95sn0aidip@4ax.com...
><snipped>
>[color=green][color=darkred]
>>>Studies have shown that the majority of the vehicles on the road have
>>>under-inflated tires, which increases the chances of a blowout. The TREAD
>>>act will require all passenger cars to have a tire pressure monitoring
>>>system so you are starting to see some early implementation.[/color]
>> This must be part of a fuel saving program?[/color]
>Probably a combination of fuel savings and safety. The Firestone Tire -
>Ford Explorer rollover problem was attributed to low tire pressure.
>[color=green]
>> It is my understanding that the sensor on my S will only detect
>> differential pressure. So if all four tires are running at a sloppy
>> 25 psi all is fine per the sensors. I should have 35-40 psi.[/color]
>I believe that your understanding is correct, however, the likelihood that
>all four tires will lose air at the same rate is pretty slim.
>[color=green]
>> Is there any real difference between the different 'slime' or any of
>> the fix a flat products? They probably have all become non
>> flammable.
>> j[/color]
>I've never used any of those products so I do not know if there is any
>difference in them. Slime is water based and supposedly sensor-safe. I've
>seen tires broken down that had those products inside and they are pretty
>messy.[/color]
I think I saw Slime - but not in a pressure bottle. The beauty is to
both fix and inflate at the same time.
Will it harm anything else to just ignore any sensor lights and
warnings?
In a few years when I need tires I'm inclined to just go to my old
tire place and have them check/rework the brakes if needed.
Any tire warranty is not worth my time or trouble.
Besides a tire plug kit, and a few tools I also carry a $15 compressor
and a can of fix a flat stuff.
j
