Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Fix a Flat
Thread: Fix a Flat
View Single Post
Old 08-03-2006, 11:41 AM   #15 (permalink)
Stuart Krivis
Guest
Posts: n/a
View Stuart Krivis's Photo Gallery
Re: Fix a Flat
On Wed, 02 Aug 2006 20:12:07 GMT, joe <nonspam@invalid.com> wrote:
[color=blue]
>In the past I have used Fix A Flat or similar inflate from a can
>products to fix 9 out of 10 flats - and who knows how many I never
>knew about.
>On the can it says "Do not use on tire sensor technology."
>Is this just another Q-tip warning to be ignored or what gives? It
>says it is non flammable -so what is the problem with simply leaving
>the stuff in the tires forever.[/color]
Not all Fix-a-flat in non-flammable. I've seen a lot of it that uses
propane as the propellant.
It also often contains ammonia, and that will corrode the heck out of
your rims and valve. It's probably not very good for the rubber
either.
The advice I've been given is to never leave Fix-a-flat in for more
than 48 hours. You should also warn anyone who will be working on the
tire that there is Fix-a-flat inside.
